Another SERT vs PCIII question
Old Dec 29, 2005 | 01:59 AM
Anthony8858's Avatar
Anthony8858
Default Another SERT vs PCIII question
If I were to exchange my PCIII for a SERT, should I expect my HD dealer have the ability to properly tune the bike with the SERT?
I ask this because I don't have a Dynon center anywhere near me, and I had concerns about using the dyno (and causing engine damage) without being properly tuned.
Do ALL HD dealers that sell SE have SERT experience?
Old Dec 29, 2005 | 02:04 AM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: Another SERT vs PCIII question
Anthony,
I like the SERT better than the PCIII because you have more tuning abilities. A good dealer should be able to set you up. Don't worry about having it dyno'd. Take it to a qualified dyno tech. They do a preliminary run to see where you are then make adjustments. Running it on a dyno for a few runs is no worse than kicking it in the *** a few times on the interstate. A good dyno tech can tune your bike with either the PCIII or SERT.
[sm=biker2.gif]
Old Dec 29, 2005 | 02:19 AM
johnnyig's Avatar
johnnyig
I had the dealer adjust my bike when they added the SE intake/mufflers etc, they installed a SERT and programmed it up to match, i think its a pretty common thing for them to do.
Old Dec 29, 2005 | 11:20 AM
CHEYENNE's Avatar
CHEYENNE
ORIGINAL: Anthony8858
No, not all dealers have a dyno as you found out or have a tech that knows the SERT
ORIGINAL: Anthony8858I ask this because I don't have a Dynon center anywhere near me, and I had concerns about using the dyno (and causing engine damage) without being properly tuned.
There is nothing to worry about by having a bike dynoed, just make sure the oil isn't low.
No as stated above.
Realisticly you can install the SERT and generic map yourself, BUT to get the most performance you will need to have the bike dyno tuned.
CLL375
Apr 16, 2007 09:37 PM
2005UltraNC
Jun 27, 2006 11:24 PM
sws1
May 15, 2006 11:44 PM
raycer
Apr 11, 2006 03:22 PM
harleymikeny
Feb 8, 2006 10:59 AM
