Pull the heat shields and loosen the mount below the trans and at the rear head, you can pull the exhaust over a bitwith a small pry bar andslide as allen wrench between the lower mount and the pipe, you only need 1/4" at most. Grind an allen wrench short on the working end so it will fit in the rear bolt, you can get the cover off without removing any of the exhaust that way. It's a tight fit but it will work...
