Newbie needs handlebar advice
Old Dec 5, 2007 | 09:41 PM
NoMistakes's Avatar
NoMistakes
Default Newbie needs handlebar advice
Winter is here in SE PA and I'm busy adding accessories to my 08 RKC.
Need some advice on handlebars. I'mthinking 2" up and 2" back and I'd like to run the wiring through the bars for a clean look.
What bars are recommended by you guys? Do I need longer cables?
Gary
[IMG]local://upfiles/38360/8B74698DD1DE4157BE6D68656F8C6A26.jpg[/IMG]
Old Dec 6, 2007 | 07:10 AM
Peppa1's Avatar
Peppa1
Default RE: Newbie needs handlebar advice
Take a look at the Wild 1 chubby bars. They have 2 versions listed for RK's. Great bars and they have just added some to fit the 08's.
Old Dec 6, 2007 | 07:13 AM
2008FLHP's Avatar
2008FLHP
i'm going w/ apes, but alot of folks like the heritage bars...i'll have some for sale in a couple of weeks if interested
Old Dec 6, 2007 | 07:19 AM
masterblaster's Avatar
masterblaster
Heritage bars for me $50 and fit is perfect.
Old Dec 6, 2007 | 07:25 AM
PhilM's Avatar
PhilM
WideGlide bars are another great option. All of your stock cables & wiring will work.
It is possible that you may need to "notch" the throttle side bar end for the electronic throttle, but Dawg recently did it and indicated that it was simple enough.
Old Dec 6, 2007 | 08:23 AM
Windup08's Avatar
Windup08
Unless you just don't like the shape and setup of the stock bars you could just try a handlebar riser. Goes between your existing bars and the fork....usually will give you about 2 up and 2 back. I've put them on other bikes in the past, don't need them on my 08 Ultra as I am very comfortable with the stock setup.
Old Dec 6, 2007 | 09:17 AM
chiefparry's Avatar
chiefparry
Does anyone have a picture of their RK with the Heritage bars. I want to see how much taller they are from the stock. I do not really want to have them "turn in" any more than the stock ones I have, just want a little taller.
Old Dec 6, 2007 | 09:25 AM
wobray's Avatar
wobray
I did the Heritage handlebars before picking up my 07 Standard. Not comf. enough. I bought the "reduced reach" bars with the wires concealed in the bars. Still not comfortable enough.
Bought (just out this year) a set of risers and a new naciele cover that brought the bars (reduced reach) back to me and now i am comfortable.
You will need your throttle cables, brakes and clutch cables all extended.
Good luck,
Old Dec 6, 2007 | 09:41 AM
Real_Big_Tex's Avatar
Real_Big_Tex
ORIGINAL: wobray
Good luck,
Unfortunately, MoCo doesn't have a way available to extend the throttle cable available yet.
BlackFLHR
Aug 11, 2013 02:44 PM
KCFLHRC
Jan 23, 2012 12:55 PM
sparky_mo
Oct 26, 2010 09:03 PM
cmhd
Sep 13, 2010 04:25 PM
PaleRearEnd
Jun 18, 2009 01:00 AM
