58MM S/E 2008 Air Cleaner number
Old Dec 11, 2007 | 12:33 AM
50thStateCycle's Avatar
50thStateCycle
Default 58MM S/E 2008 Air Cleaner number
My 08 s/e air cleaner arrived today. Part number is 29515-08.I was in the process of install and noticed that the contoured surface of the backing plate does not meet with the opening of the carb. I looked at box and said it was for a 58mm throttle body. Is there another kit that fits the stock opening of a Ultra?Is this how its supposed to be or is this the kit that they use. If someone has something please advise. This is the second kit that the dealer has ordered. The first one was for a 07 model. Thank You
Old Dec 11, 2007 | 03:58 AM
dt20's Avatar
dt20
Default RE: 58MM S/E 2008 Air Cleaner number
this is the one I got. heres the part number of the kit I got 29260-08 kit SE stage 1 a/c 50mm also states that its for 2008+ later touring models. also make sure you take the black metal bracket off on the throttle body housing other with the backing plate will not seal correctly.
Old Dec 11, 2007 | 06:02 AM
pkenyon1's Avatar
pkenyon1
Maybe you did not get the touring version??
Old Dec 11, 2007 | 01:06 PM
50thStateCycle
Looks like I did not. Can you believe this is the second time I will be taking this thing back. When it rain its poars.
Hit by car from behind
Recovering from injuries
Got infected with MRSA from hospital
Shipping company loses my L-79 Nova block
Dealership continually orders wrong part
HELP.......
50thStateCycle
I really appreciate the help
Old Dec 11, 2007 | 02:12 PM
Trock's Avatar
Trock
As dt20 said, if you don't remove the bracket it won't fit. It doesn't tell you that in the instructions for some reason. I guess you could double up on the gaskets if you don't want to remove the bracket.
Old Dec 11, 2007 | 03:29 PM
dt20's Avatar
dt20
50thstatecycle,
just want to make sure we are talking about the same AC the one that you reuse your AC cover correct not the L shaped cleaner? the part number I gave you was for the one that you would reuse your cover not the heavy breather that apparantly is L in shape and the filter is exposed.
Old Dec 11, 2007 | 07:50 PM
50thStateCycle
The dealer had the correct part in stock. The number you gave me is correct. I reused my original air cleaner for the sleeper look. The bracket is attached with two screws on top of the throttle body and too both jugs does get tossed. If you dont toss it there will be a gap the exact thickness of that bracket between the throttle body and the new backing plate. You are also correct it does not state this in the instructions. Also I glued the black rubber strip to the air cleaner so it wont fall off while riding. There is a slight mis alignment between the backing plate and the throttle body. The transistion is not as smooth as I would like it, the only fix would be to port the throttle opening more. Sounds like more mods than I need. Thank You once again and good thing we have this forum.
Old Dec 11, 2007 | 08:13 PM
dt20's Avatar
dt20
glad it worked out for you. i didnt bother with the black strip on the outer cover just left it off.
jbrooksca
Dec 15, 2016 10:53 AM
JJHOG
Touring Parts
Jul 12, 2013 04:52 AM
voudoujoe
Dyna Parts
Mar 15, 2013 08:03 AM
fripple
Touring Parts
Aug 13, 2009 08:47 AM
uweldit
May 9, 2009 11:07 PM
