true duels
what are the opinions on
BassaniÂŽ Power Curve Crossoverthanx for your input...
On subject now, I saw a sideby side torque curve dyno sheet between the Bassani Power Curve and the Bassani Road Rage 2 into 1. The Power Curve had a slight dip at low rpm but recovered quickly and ran fairly close the rest of the way. I have had both pipes, although on different bikes, and liked them. The Road Rage really woke my modified Evolution up compared to stock headers with slip ons. The Power Curve looks and sounds great and my keester meter likes it too but the dyno would know the difference. It comes down to, are you racing or riding?
I'm going with the "untrue duals". Bub 7 with crossover pipe. Balanced oiutput with no low-end torque loss.
Stock pipes emulate 2 into 1s, since the left pipe is partially obstructed, which allows 80% of the exhaust to escape out the right pipe. 2 into 1 pipes provide the best low end torque and HP. Supposedly has something to do with backpressure.
True Duals provide more higher-end HP, less lower-end. This is usually compensated by the use of a tuner and dyno, therefore the end result is equal to or slightly better than the stock configuration.
Introducing a cross-over pipe on a balanced exhaust system improves lower-end torque and HP. (In the 70's we had dual exhaust systems on cars which would utilize a cross-over pipe for the purpose of getting better low-end torque and HP.)
I have read many threads where true dual owners have dead or weak spots at around 2500 rpm, but indicate that they recover quickly, but is still noticable. I'm sure that proper tuning through mapping and a/c configuration can overcome this in most cases.
I'm not sure what these Bub 7 crossovers are going to be like, since I haven't put them on yet. They use a stepped header technology running from 1 7/8" to 2". I was concerned with having HP loss with pipes this large in a strictly true-dual configuration, so I went with the crossover.
So just putting slip-on muffler systems on stock headers doesn't resolve the issue where 80% of the exhaust comes out the right side. You might as well get 2-1 that uses a ghost pipe.
If I don't like the Bub 7s, I won't hesitate to chuck em. But based on what I've been told, they're supposed to be damn good pipes with a deep throaty sound and excellent performance.
