The stock pipes are closer to a 2 into 1 than a dual with crossover. the reason is the stock system has a tee of off the side of the rear cylinder pipe (look under the front of your seat), not a crossover or balance tube like the Bub crossover. The only thing it does is make for a unbalanced system. If the down tube from the rear cylinder connected to the side of the rear cylinder pipe like it connects to the side of the front pipe then it would be a balanced system (with crossover). GliderXXX explained this also. The stock pipe looks good until you see the poor engineering. I sold my stock system (and 2 others) on ebay. I wont put that system back on my bike! I hope I haven't misspelled any words or used improper grammer!
I have the Power Curves on my SG with Reinhardt Mufflers..... The Power Curves are a true tuned header.... Unlike alot of other popularpipes. There is no additional heat that I can feel from the back loop. The peformance difference after addingSE 211s cam and SERT is pull your arms off.....
Someone posted a loss off 20lbs of torque with duals versus 2 into 1s....As I stated no doubt its possible on a stock engine. And not all big money pipes are worth the big money.
I am barely sub 100 Tq out of this combo... I doubt my tuned dual exhausthas left me short ofanything like this sitting on the table.....
ORIGINAL: Thrak
I have noticed most people with duals have V&H
what are the opinions on BassaniÂŽ Power Curve Crossover
thanx for your input...
You have alot of growing up my small minded little friend, I never threatening you at all just wanted to know what Mr Prefect was doing and wanted an apology for your insults
So let me get this straight, you've called me small minded, sent insults and threatsthrough the email system of this board, and the want me to apologize to you..................... okay sorry to have insulted you and your endeavors to spell...... so I'll wait for my apology................... waiting...................[:'(] still waiting..........[:'(]
I have not been on this forum that long but I have notice people like you and two others that posts threads and little comments and try to let the other hundreds or thousands on here that they are better than anyone else and I'm tired of seeing it, You are not better than all the others on here and I'm letting you know it
The only thing I said was don't make a mistake or I will call you on it and it was your next post you did by not putting acap at the start of a sentence.
Like most other post on this thread you should not throw stones Mr. prefect, I and others are here to learn Harleys from these post not to be made funny of by a simple typo.
Some of these guys on here are invaluable to people like me and I don't want small minded people like you Kwas to ruin a wonderful thing by being a smarta$$
