need help with tank float
Old Jan 1, 2008 | 09:57 AM
big_al's Avatar
big_al
Default RE: need help with tank float
Damn I thought changing a fuel sending unit in a car was hard but the harley one seems alot harder...
Old Jan 1, 2008 | 11:09 AM
NoKenDo's Avatar
NoKenDo
The trick is to cut the clamp on the hose at the rear of the
pump assy, lift the assy so you can see the pump.
Then use a screwdriver to push down on the pump.
As you push down it releases the hinge, then with a little
finesse you should be able to work it out.
Old Jan 1, 2008 | 12:51 PM
bigmack's Avatar
bigmack
ok well now that i have it out and didnt f*** ANY THING UP is there any tips on putting it back in and getting locked in place
pwal
Nov 21, 2015 09:54 AM
Btechpat
Aug 30, 2012 11:17 AM
dannycalderone
Feb 22, 2011 07:22 PM
sprint12
Oct 5, 2008 08:08 PM
rad131313
Jan 28, 2008 07:24 PM
