Should the stealer check this
Old Jan 10, 2006 | 08:32 PM
yota's Avatar
yota
Default Should the stealer check this
When entering say a parking lot and I hit the bump entering the driveway, I hear a hmmmm clunk noise. Is something not tight. What can I do to check this out myself as I want to get away from seeing them a bunch if I can avoid. 05 Ultra..Any ideas..Could it be front forks or the neck bearings not to spec for torque..I now have as the spanish would say emanuel for this ride so I can look up specs for some of this but looking for a direction..If anyone knows what it maybe also some knowledge on what needs to be done would be great..Thanks in advance...By the way, winter here in Calgary Alberta so not a panic repair..HELP IF YA CAN.
Old Jan 10, 2006 | 11:14 PM
klemmer's Avatar
klemmer
Default RE: Should the stealer check this
What winter I've seen your temps. send some of that weather my way and I would be riding
Old Jan 10, 2006 | 11:22 PM
redscout's Avatar
redscout
Man, you guy's winters must SUCK!
I thought I had it bad down here.... What's the riding season up there in North, North America (I've heard Canadians HATE that). Eh? (sorry, but evidently I say "warsh" when I mean "wash", so it's a regional thing).
Old Jan 10, 2006 | 11:23 PM
UGGA's Avatar
UGGA
Could be several things, but it sounds like loose steering head bearings to me.
Old Jan 11, 2006 | 02:23 AM
mikeisglidn's Avatar
mikeisglidn
when the air is low in the shocks, mine sound like a log wagon, something to look at............cheap!!
Old Jan 11, 2006 | 03:13 AM
KBES BAGGER's Avatar
KBES BAGGER
Hold your front brake and rock your bike forward, listen up front, if it is your neck bearing you will be able to tell this way.
KB
Old Jan 11, 2006 | 02:14 PM
04RoadKing's Avatar
04RoadKing
Does it make that sound only while in a turn or all the time, like if you pull into your drive in a strait line? Is the sound comming from the front or back of the bike? If it's the front and it's all the time the fork oil could be low. It might not of got filled up all the way.
That happend to my on my 01 Softail. Everytime I'd go over a bump at low speeds the front end would make that same sound. So I took it back to the dealer and they changed the fork oil and the problem went away. Something to look into?????
Skid Lid
Feb 17, 2012 08:32 PM
mechmagcn
Aug 27, 2011 10:09 PM
russell6hp
Jul 13, 2010 03:52 AM
MJHJEA
Mar 30, 2009 07:04 AM
BoaJoe
Mar 8, 2009 03:11 PM
