Andrews cam outer gear question
Old Jan 16, 2008 | 02:56 PM
schmeg's Avatar
schmeg
Default Andrews cam outer gear question
I'm currently building my 01 FLHT to 95" with mild head work and a set of TW21's chain type (yeh I know still no gear drive) but I wanted to keep the build cheap for now, Full up 120 later down the road. My question is Andrews claims you have to use their outer gears when installing their chain type cams. Is there a valid reason why you can't use stock harley gears? I happen to have new OEM harley chains and gears and such. Just didn't want the additional expence for nothing. Thanks for any info.
Old Jan 16, 2008 | 06:05 PM
maineultraclassic's Avatar
maineultraclassic
Default RE: Andrews cam outer gear question
There are no outer gears when using chain drive cams............there are no gears at all when doing a chain drive cam install.
Steve
Old Jan 16, 2008 | 06:57 PM
Grover's Avatar
Grover
Administrator Emeritus
I believe the term he should have used is sprockets.
Old Jan 16, 2008 | 07:20 PM
mtclassic's Avatar
mtclassic
ORIGINAL: schmeg
that is only true for 99 models. Your 01 should not need it.
Old Jan 16, 2008 | 09:11 PM
schmeg's Avatar
schmeg
I apologize for using the wrong nomenclature. As pointed out I should have used the term sprockets. Thanks MT, thats the answer I needed.
Quiet Thunder
Nov 27, 2016 12:12 PM
azharleyrider86401
Mar 29, 2011 06:03 PM
Tanker2
Exhaust System Topics
Sep 22, 2010 05:53 PM
pauletich
Apr 12, 2008 04:41 PM
joe v
Apr 10, 2006 02:40 PM
