06 Throttle Cable "Slop"
Old Jan 16, 2006 | 12:13 PM
trex_47e's Avatar
trex_47e
Default RE: 06 Throttle Cable "Slop"
Had the slop when I bought it, tighted it up at home in the garage. Had it back for some work at the dealer...same darn thing...sloppy. I had them fix it this time, now it's perfect. Not to little...not to much. So....my experience is the dealer mechs love a little slop in it.
Old Jan 16, 2006 | 01:48 PM
Rhinohd's Avatar
Rhinohd
OK, I put new grips on this weekend and found that if you take all the slop out the throttle it will not snap back. I loosened it a tiny bit and bam it worked like a charm.
Old Jan 16, 2006 | 01:58 PM
HDF Tech's Avatar
HDF Tech
SOME slop is necessary so they don't bind, also try the forks full left and right with the motor running to make sure they are not too tight and opening the throttle .Excessive slop can be adjusted out, take a look here... https://www.hdforums.com/m_121865/tm.htm
Old Jan 16, 2006 | 03:28 PM
Bruce00's Avatar
Bruce00
ORIGINAL: Upswept
Why don't you adjust it yourself? There are two cables, a pull cable at the front of the throttle grip and a return cable at the rear of the throttle grip. Loosen both of them so they are very sloppy. Then adjust the pull, the front cable, until you get full throttle. You will be able to hear it click at full when you open it up. Then, adjust the return, the rear cable, to get whatever amount of slack you desire. It's an easy one minute job.
ORIGINAL: TCSTD
I've adjusted many throttle cables on my old bikes (read Carb single cable equipped)
Went thru many throttle cables installing the Super B S&S (thats a long time ago) and the Dual Throat S&S (Remember those?)
So this FI thing had me a little apprenshive (sp?).
Then after reading my $56 serive manual, the talk about the ribbon on the cruise control, had me more confused then ever.
I just wanted to hear that "adjusting a little" slop out, wouldn't screw up the cruise or send the cpu into fits.
I guess the only way to find out for sure would be to try myself, but its in the mid 20's and my garage doesn't have heat............YET
Thanks for the responces
Old Jan 16, 2006 | 04:28 PM
wuznme's Avatar
wuznme
You can adjust the cables to remove the slop....I did before and after changing the bars out...no issues. The cruise can be readjusted after the slop is removed.
Old Apr 25, 2006 | 01:52 AM
Whiffleboy's Avatar
Whiffleboy
Gonna bump this one up since I have a related question about my 06 Dyna...
After installing my Kurykayn grips, I find the right grip feels loose and sloppy. Like, I can rattle it around at a stop light. I want to tighten it up a bit but the tension screw under the housing isn't fixing the problem as the grip sticks too much. I decided to adjust the throttle/idle cables...
I adjusted the throttle cable properly, but, I'm having problems with the idle cable. Looking at the throttle body, I can't seem to get the cable to move away or towards the spring in the little slot [as described in the manual] no matter how much I turn the adjuster. The grip snaps back OK, but, it's nowhere near as good as my stock set up. So, I'm looking to get it dialed in. Any help would be appreciated.
Whiff
Old Apr 25, 2006 | 02:25 AM
Stucarius's Avatar
Stucarius
Any slop that shows up with riding is easily adjusted right out. To me it is just part of maintenance and every one probably has a different tolerance. Right now I have 0 slop. Super tight and I have done a grip update and plan to internalize the throttle cables and mechanism soon anyway.
Old Apr 25, 2006 | 10:13 AM
Bruce00's Avatar
Bruce00
Since this thread has surfaced again, I'll add this.
I finally got sick of the "slop" and adjusted every bit of it out, then backed it off a "See U next tuesday" hair.
After a 1000 miles no problems so far and Iam liking the throttle ALOT better
Old Apr 25, 2006 | 10:48 AM
BUBBA's Avatar
BUBBA
I just notticed the Slope after i had the Cruise control installed.
went back and they adjusted my throttle now there is a little bit of play not as bad.
Old Apr 25, 2006 | 12:44 PM
nmfxstc's Avatar
nmfxstc
If you are on a scoot with electronic cruise control, this may be part of the trouble:
Cruise Control Cable Lash Initialization
For Harley Touring Models
1.) With the Ignition off, push the right cruise switch to RESUME and hold it there.
2.) Push the left cruise on/off button to ON.
3.) Turn on the ignition switch and crank the engine. The GREEN ENGAGED light will illuminate for three seconds and go out. When it goes out, release the RESUME switch.
4.) With the bike still running, push the right cruise switch to RESUME again and hold it while the unit pulls in the slack in the cable. When the engine revs up a bit and the green light goes out again, release the RESUME button and turn the ignition switch off.
128auto
Aug 28, 2012 09:10 PM
katobird
Mar 6, 2012 08:07 AM
dope_man_21
Screamin Eagle CVO Models
Nov 16, 2008 11:38 PM
labfreak
Jan 7, 2008 11:51 PM
EagleArmsHBAR
Jul 21, 2006 11:10 AM
