IDS Bearing failure
Old Feb 14, 2008 | 05:49 AM
  #31
relli's Avatar
relli
Default RE: IDS Bearing failure
ORIGINAL: sparky_mo
[sm=chattypair.gif]
I think probably so. Amazing how fast we conclude that it's going to be a major problem leading to disaster after only one post with a bad bearing shows up.
We probably should be asking some V-Rod guys since they have always had the IDS installed on their bikes. Wonder if any of them have had any problems with the bearing.
good point !!!maybe we should. i recntly changed rear tire with over 10K on the IDS and no problems to report.
Old Feb 14, 2008 | 06:57 AM
  #32
sparky_mo's Avatar
sparky_mo
ORIGINAL: choochoo
I tried to tell you it was a BANDAID.
But ya all didn't listen.
You reap what you sow!!
eventually that bad bearing will ruin the wheel.
then instead of $20 try $300 -$600 depending on the wheel
Glad so many of you have money to spare and don't have to worry about it!!
Now I am concerned since the 'great and powerful Choo has spoken.' Choo has been an expert on the 07's since they came out. He has more than once told us 07 owners that we all f....d up buying one. I have never known Choo to be wrong about anything so I'm thinking all of us who purchased the IDS are all doomed. I am still puzzled how you know so much about the 07's since you ride on 06. Oh well, I'm SURE your right again. As soon as the weather warms up I'm taking my bandaged 07 in and tell them Choo sent me. They do know you are an expert on all Harley's don't they Choo?
Old Feb 14, 2008 | 07:56 AM
  #33
dgriffith's Avatar
dgriffith
Just an observation, Is it possible that the spacing between the 2 haves is too thin? Thereby, bottoming out the halves together causing excessive side load on the bearing when torquing the axle nut? Is it possible the spacers are in the wrong location? Thick 1 in and thinner one out or vice versa.
  #34
UltraKla$$ic's Avatar
UltraKla$$ic
At no time did the bike exhibit any handling problems. I don't think a rear wheel lockup would have been likely.
Please be sure to post your results if/when it happens.
I'm not crying the sky is falling, but a bearing that provides the structural integrity of the wheel design/function coming apart at speed has the potential to reek havoc on rider, passenger, and bike I don't care who you are.But again, WTF do I know?
Alot of issues come into play when discussing the cause for this potential disaster and in the beginning alot of people were doing the HOT/COLD installation which may possibly distort the integrity of the bearing and/or sprocket with said method. Some may have developed small hairline cracks while being overly pressed unbeknownst to the person pressing the bearing in and therefore cracking the lip on the sprocket itself that the bearing resides against and/or damaging the integrity of the bearing itself with too much pressure.
There are special tools needed for this job as recommended by HD and for those of US that may have found other modalitiesfor arriving from point A topoint Bmay have to pay even that much more attention to our setup versus one that had it installed by the dealer properly, and even then there is no guarantee since this could be a flaw in design, bearing, and/or both.
Whatever the cause, I just hope the effect doesn't take a valuable life with it. I said VALUABLE so alot of you have nothing to worry about if something does happen.[8D]
Old Feb 14, 2008 | 07:58 AM
  #35
rickoshay45's Avatar
rickoshay45
One failure out of how many installed? I've probably got over 12k or more on mine with no proplems. At this point I will watch out for issues but I'm not going to panic.
Old Feb 14, 2008 | 08:18 AM
  #36
UltraKla$$ic
So the end of the world isn't upon us? Aw man! I just ran up all my credit cards on a spending spree thinking I was getting out of here today!
Old Feb 14, 2008 | 10:08 AM
  #37
Dennydp's Avatar
Dennydp
Ive often wondered about the hot/cold bearing install damaging bearing
Old Feb 14, 2008 | 11:07 AM
  #38
Mikind7's Avatar
Mikind7
Any way you install a bearing, as long as you only apply pressure to the race being fitted and that presure is even, there should be no damage, in this case applying pressure only to the outer race should be OK, don't press it in using the inner race\races at all, IMO
Old Feb 14, 2008 | 11:24 AM
  #39
Scootr's Avatar
Scootr
I will have my wheel off in about 2k miles for a new rear. I will keep this in mind and inspect then.
Old Feb 14, 2008 | 11:55 AM
  #40
nwbobnw's Avatar
nwbobnw
Hope everything works out guys. Meanwhile I'll keep my 07 SG stock and wait and see.
