IDS Bearing failure
The bearing is made by *** Bearing, but I cannot research it with out a readable/correct number
It is also possibly installed incorrectly/backwards....I can't be sure until I get the bearing # and install instructions
Edited to say I found the instructions...Go here, then click the pdf file:
http://www.box.net/shared/hotj1llvt0
design like HD did.
I think your all too paranoid....
Japanese bikes have been using this same isolation method for years and Its never been a problem. I have a 37 year old Honda that I just finished rebuilding and when I removed the rear wheel the original bearing and rubber isolators were still installed and still functioning fine.
I installed an IDS on my 07 ultra myself and pressed the bearing using just an arbor press and it went in fine without the hot and cold method most are describing.
I have read some haveused the hot and cold meathod and pounded the bearing in with a block of wood and a hammer. I can see mabe this method causing a bearing to fail.
Just my opinion......but I think most on this forum worry too much.
I will agree longevity depends on a lot of things, riding style, how installed,etc.
But bottom line is in 08 HD knew they f...ed up in 07, that's why they brought
this out.
And isn't it convienent they designed it so it could beused retroactive on 07 wheels??
someone shows me proof I'm wrong on a subject, I have owned up to it, here on this forum.
I've been doing mechanical repairs on all types of equipment since the 70's, pretty sure (not positive though) I got good experience in designs, what holds up what doesn't, and have seen
numerous manufacturers redesign something as first design did not hold up in the real world.
Even though it looked good on paper and in testing.
so as I said above BITE ME!
I tried to tell you it was a BANDAID.
But ya all didn't listen.
You reap what you sow!!
eventually that bad bearing will ruin the wheel.
then instead of $20 try $300 -$600 depending on the wheel
Glad so many of you have money to spare and don't have to worry about it!!
[IMG]local://upfiles/51968/9B2464E6EECF4F849317014377181FD9.jpg[/IMG]
ive got 3500 miles on the ids, dealer installed, after they got the special tool they needed for install.
If you look you will see the outer race is installed with the thin side out, and the inner race has it's thick side out.......If you were to flip the bearing over, the outer race thick side would be outside and the inner race thin side likewise....Does it make a diff?...I dunno in this application, but often it does....It depends on thrust loads, but there should be no axial thrust generated if the spacers are installed correctly.
By-the-way, the assembly is designed so that the supplied spacers clamp against the inner race, so torquing the axle nut should only exert force there....As long as you got the spacers right, then there should be no problem.
The instructions don't say which way to flip the bearing when you install it.....That's maybe an omission by mistake.
Come on guys,post the details and more pics...........I'm a commissioned Boiler Inspector and pretty good at failure analysis.....We have the answer. All we have to do is share the details to sort it out.....If HD discovers it, odds are we will never hear about it.
