IDS Bearing failure
Old Feb 15, 2008 | 01:08 PM
  #61
Biggzed's Avatar
Biggzed
Default RE: IDS Bearing failure
ORIGINAL: YodaddyKeith
Look at the bearing in the pic.......
If you look you will see the outer race is installed with the thin side out, and the inner race has it's thick side out.......If you were to flip the bearing over, the outer race thick side would be outside and the inner race thin side likewise....Does it make a diff?...I dunno in this application, but often it does....It depends on thrust loads, but there should be no axial thrust generated if the spacers are installed correctly.
Yodaddy - Can you explain this a little more to us? If the spacers are riding on the inner race, and the pulley is only soft mounted to the bowl, then wouldn't there still be the possiblity of an axial thrust to the outer race? What if the pulley was not rotating exactly on plane, or if sudden force was applied to the pulley (ie. burnout, wheelie, locking the rear brake)? These are hypothectical actions, I'm not accusing anyone of doing this, just trying to understand more about what may have caused this.
I'm the first to admit I may not understand axial thrust also.
BTW - It looks like the *** part number for the bearing is 559763. The other part# appears to be HD's number for that part. Could be wrong though.
Zach
Old Feb 15, 2008 | 01:56 PM
  #62
YodaddyKeith's Avatar
YodaddyKeith
Yeah, those are the numbers I perceived/saw on my new hi-res laptop screen, but they don't cross on the *** bearing site.....They are still rather fuzzy, tho...You are correct, the other # is an HD number which does me no good.
You are most correct that the belt pulley should not experience side loads....The bearingshould be clamped by the spacers only at the inner race like the wheel bearings and thusly then be like it was a part of the axle where the inner race is stationary and the outer race revolves around it with the pulley...it should be a kinda tight/slip fit on the axle, but an interferance fit in the hub bore....The only loads on the bearing should be radial in nature and limited to the torque applied by the belt/tranny plus belt tension.
So far all I can deduce is possible installer error where they might have damaged the bearing from improper install tactic or getting the inner spacer confused with the outer........The only other possible cause so far is simply a poorly made bearing or the wrong bearing design for the application.
I really need folks to help narrow it down by supplying the extra requested info......Who installed it, did they use the HD tool set to install it, and also was it an '08 or '07?
you gotta remember that this device was designed/intended to absorb shock loads from the engine/tranny.....It might be that the bearing needs to be more substancial with a larger/thicker inner race...that would require it be larger in diameter overall.......I'd like to see the V-Rod pully bearing and compare them.....The V-rod makes much more HP, so if they use similar sized and design bearings, then it must be related to install or something else.
Old Feb 15, 2008 | 03:52 PM
  #63
pittguy's Avatar
pittguy
Alot of owners now have this setup installed on 07s and all the tourers in 08.I would say so far if indeed its a problem its very very limited and probably due to the person that installed it.The kit made no reference of brg side direction.Someone posted that the tq values on attaching bolts to wheelhas been increased to 80 ft/lbs.Have yet to see anything in writing,if true the message boards are going to have to get this word out because not everyone had their local dealer install these kits.Several here work at dealers,factory,and if the tq values have been changed maybe they could post.Im sure HD wants this enhancement issue to go away.
Old Feb 15, 2008 | 03:59 PM
  #64
RangeRat's Avatar
RangeRat
80 ft lbs is true - a new bulletin and saw a copy posted yesterday - no search function so I'll go hunt manually and post a link if I can find the string again...
...here go:
https://www.hdforums.com/m_2873259/tm.htm
Find the post where dawg posted a snip.
Old Feb 15, 2008 | 04:00 PM
  #65
iclick's Avatar
iclick
The instructions don't say which way to flip the bearing when you install it.....That's maybe an omission by mistake.
I'm listening and learning. From reading the instructions, at least we have a 50:50 chance of installing it with the proper orientation, if there is one.
Come on guys,post the details and more pics...........I'm a commissioned Boiler Inspector and pretty good at failure analysis.....We have the answer. All we have to do is share the details to sort it out.....If HD discovers it, odds are we will never hear about it.
Perhaps the OP could ship the damaged bearing to you. We could use an expert opinion, I'm sure.
Old Feb 15, 2008 | 04:07 PM
  #66
pittguy's Avatar
pittguy
https://www.hdforums.com/upfiles/136...C834A06BEC.jpg got it thanks.
Old Feb 15, 2008 | 04:23 PM
  #67
RangeRat's Avatar
RangeRat
No sweat. I see now it's an '08 manual update though, not a bulletin. Therefore hard toknow ifit applies to IDS retrofit on '07 too but...
Old Feb 15, 2008 | 04:30 PM
  #68
YodaddyKeith
Iain't no expert, butI did a failure analysis on the old r22 toyota cam chain tensioners once....The aftermarket ones were hydrolocking and causing accellerated cam chain wear.....I bought one and cut it apart and fingered out the problem....The guy buying them from China for resale here had them redesign and experienced no more recalls/returns.
Usually, it it leaks, stinks, or squeaks i can fix it....Or break it trying.
Old Feb 16, 2008 | 02:02 AM
  #69
WildBill2566's Avatar
WildBill2566
ORIGINAL: Biggzed
Ok, I'm confused about one thing. In the picture below it looks like the part with the rubber isolators gets firmly bolted to the wheel hub with the 5 bolts. What secures the actual pulley part to the part bolted to the wheel hub?
I'm assuming the bearing gets pressed into the opposite side of the pulley, the spacer gets installed in the side of the pulley that is shown in the pic, and the washer goes between the pulley and the part bolted to the hub. I couldn't quickly find the install instructions to confirm this, but that's what I see by looking at the pic.
So my question is, what hold the pulley to the part bolted to the hub? Is it just the pressure of the pressed in bearing against the wheel to swingarm spacer? God I hope not.
(Deleted......Comments already covered by other posters)
As for the bearing failure thing, well I'm sorry for those involved but I won't be sounding any alarm just yet.
Any bearing can fail for any number of reasons, and if you make enough of any items, one of those items will fail/break sooner or later.
Old Feb 16, 2008 | 05:23 AM
  #70
relli's Avatar
relli
had mine installed by zanotti. no prob as of yet with over 10k.
