$220
Old Jun 19, 2008 | 04:04 PM
  #31
dgriffith's Avatar
dgriffith
Default RE: $220
I carried in the rear tire assy. had the tire replaced with narrow w w.&nbsp\\; New tire mounted and balanced with labor $197. Columbus IN
Old Jun 19, 2008 | 04:09 PM
  #32
soos's Avatar
soos
Default RE: $220
pete, that is still too much for a front tire. Which dlr in NH?
I got 3 quotes from 3 NH dlrs closest to me for front and rear replacement D402's.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; $455.00, $431.00 and $395.00 mounted, balanced and installed. The last quote is my local dlr and they don't require an appointment. In by 3 out by closing. I will be there when they open.
I should add that the tires are blackwall and were $221.00 pair.
Old Jun 19, 2008 | 04:39 PM
  #33
petemac's Avatar
petemac
Default RE: $220
soos, it was Nashua HD. Which dealer gave you the best price and doesn't require an appt.
&nbsp\\;
This is for the D402 with the wide white wall. Front tire.
&nbsp\\;
&nbsp\\;
ORIGINAL: soos
I got 3 quotes from 3 NH dlrs closest to me for front and rear replacement D402's.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\; $455.00, $431.00 and $395.00 mounted, balanced and installed. The last quote is my local dlr and they don't require an appointment. In by 3 out by closing. I will be there when they open.
Old Jun 19, 2008 | 04:40 PM
  #34
dhincc's Avatar
dhincc
Default RE: $220
Update. Went with the blackwall (can't see the back tire anyway!) and it's ~ $155.00 + tax. Free installation. That's the Dunlop 402 at the Corpus Christi HD. And that's the BACK TIRE!
Old Jun 19, 2008 | 04:44 PM
  #35
soos's Avatar
soos
Default RE: $220
ORIGINAL: petemac
soos, it was Nashua HD. Which dealer gave you the best price and doesn't require an appt.\\;
This is for the D402 with the wide white wall. Front tire.\\;
ORIGINAL: soos
I got 3 quotes from 3 NH dlrs closest to me for front and rear replacement D402's.&nbsp\\; $455.00, $431.00 and $395.00 mounted, balanced and installed. The last quote is my local dlr and they don't require an appointment. In by 3 out by closing. I will be there when they open.
Seacoast in \\; N. Hampton. 1-888-333-0001
Hey pete, Seacoast is the same price as Nashua. Didn't realize that you have spokes.
Old Jun 19, 2008 | 04:56 PM
  #36
petemac's Avatar
petemac
Default RE: $220
Thanks soos. I have 23k on my original front tire and time to replace it.
&nbsp\\;
&nbsp\\;
ORIGINAL: soos
ORIGINAL: petemac
soos, it was Nashua HD. Which dealer gave you the best price and doesn't require an appt.\\\\\\;
This is for the D402 with the wide white wall. Front tire.\\\\\\;
ORIGINAL: soos
I got 3 quotes from 3 NH dlrs closest to me for front and rear replacement D402's.&nbsp\\;\\\\\\; $455.00, $431.00 and $395.00 mounted, balanced and installed. The last quote is my local dlr and they don't require an appointment. In by 3 out by closing. I will be there when they open.
Seacoast in \\\\\\; N. Hampton. 1-888-333-0001
Old Jun 19, 2008 | 04:58 PM
  #37
soos's Avatar
soos
Default RE: $220
ORIGINAL: petemac
Me too. Goin in tomorrow morning then heading up to Laconia for the day.
Old Jun 19, 2008 | 05:24 PM
  #38
tyrant33's Avatar
tyrant33
Default RE: $220
So it would of been cheaper if you didn't get the custom scratch and decolorization of the frame? [8D]
&nbsp\\;
&nbsp\\;
&nbsp\\;
ORIGINAL: tgaetto
223 in and out service @ Smokey Mountain last August complete with bag&nbsp\\;scratch and discolored frame by using some type of degreaser?
Old Jun 19, 2008 | 05:46 PM
  #39
Jinks's Avatar
Jinks
Default RE: $220
ORIGINAL: tgaetto
The scratches are why I started doin' my own 20 years ago.&nbsp\\; The shop "tire monkey" isn't paid enough to care about *your* bike.
New Dunlop sittin' on my shop floor cost $117 delivered.&nbsp\\; It'll cost me 'bout an hour (maybe two if I'm lazy) when I get around to changin' it.&nbsp\\; I changed a neighbors front tire on his Triumph yesterday.&nbsp\\; We spent an hour or so tinkerin', talkin' &amp\\; changin' his tire.&nbsp\\; I balanced his wheel (without the tire), the heavy spot on that wheel is about 90 degrees from the valve stem.&nbsp\\; Then we mounted the tire &amp\\; balanced it.&nbsp\\; Took fewer weights than it would have if a shop had just jammed the tire on with the weight mark at the valve stem.
When I mount new tires on my FLTR I'll be installin' these...&nbsp\\; www.motorcycleanchor.com/tire_valves/index.htm
I'm a lot more comfortable with the work I do than what I get at shops.
Old Jun 19, 2008 | 05:51 PM
  #40
petemac's Avatar
petemac
Default RE: $220
Have fun.
&nbsp\\;
&nbsp\\;
ORIGINAL: soos
ORIGINAL: petemac
