dyno tune advice needed
Old Feb 22, 2008 | 12:24 AM
hogdoc's Avatar
hogdoc
Default RE: dyno tune advice needed
ORIGINAL: rochkes
oh yeah........ I meant to show some more of my ignorance by asking what is a FBY bagger? I get the bagger part, but FBY?
Dennis
FBW not FBY stands for Fly By Wire, it means you have no throttle cables to connect yourgrip to the throttle body. It is controlled by a servo motor mounted on the T/Body itself. It has some lag time from when you whack it wide open to the T/Plate actually opening all the way. But this is good for TQ. Kinda like running a Mikuni Flat slide carb.
With the parts you listed, tuned right you should see about 85 HP and 95-100 TQ
Old Feb 22, 2008 | 07:37 AM
choppers4life1's Avatar
choppers4life1
Technically--It's drive by wire.
Old Feb 22, 2008 | 07:51 AM
Jinks's Avatar
Jinks
ORIGINAL: hogdoc
ORIGINAL: Jinks
Most of the time it won't make a difference what you tell the tech. The majority of them tune for power. They feel that if you're on a dyno you're lookin' for every last ounce of horsepower & pound of torque. That usually results in a rich mixture that'll give you those big numbers & moderate to poor gas mileage.
Jinks, your bass ackwards there my friend, to get the higher #'s you run it lean to make more power not rich.
And yes a GOOD tuner will get every last ounce of HP & TQ......... at WOT and thats what WOT is for. Thats what YOU guys ALWAYS WANT, BIG #'S. But there is also 0,2,5,7,10,15,20,25,30,40,60, and 80% throttle settings that get tuned for all riding conditions. You will get poor gas mileage when you first get your bike back from us becuase your gonna be so happy with the way it runs youll be on the throttle all the time.
Notice that I didn't say "the good tuners", I said the majority. You're right about "lean bein' mean", but that wasn't my point. Neither you or I know his tuner, but it sounds like he *might* have a good one. You're also right in that *most* people that put their bikes on a dyno want big #'s. Puts you tech's in a tough spot unless your management encourages you to take the time to talk with the customer. Even then there are more people that think race track numbers are the way to go with a street bike than there are people that understand the difference.
Personally, I think dyno's are an unnecessary expense for street tuned bikes unless you're trying to fix a particular problem & know a really good tech. As others here have attested, a poor tuner can do as much harm as good.
Old Feb 22, 2008 | 08:59 AM
rochkes's Avatar
rochkes
once again guys, you are helping me not only make up my mind what I am going to do, but you are helpin me feel confident that I actually know what I want.
As far as my tuner being a good one, your guess is a good as mine. The guys at Legacy HD in Effingham are treating me like a friend because I have dropped between 40 & 50K in their store in the last3 years or so, but I haven't been able to talk to anyone who has actually had their bike tuned by them.
That being said, since I am very pleased with the way the bike runs, I think I'll just have them do a dyno pull with me being present just so I can have some fun and learn something new. I see no need to change anything unless the tech tells me he is sure he can pull more hp and tq and still have the bike running right.
Would any of you be concerned about the puff of smoke on start-up that I described earlier? All the Harleys I have been around before have been stock and I have never saw this on any of them.
Dennis
Old Feb 22, 2008 | 12:36 PM
Jinks's Avatar
Jinks
Sounds like a good sensable approach, particularly if the tech will work with you. As for the black smoke, yeah it's probably gas. Fuel injection pushes some gas to get started with. Your tech may be able to adjust that in the SERT. I wouldn't be concerned as long as it doesn't do it every time you blip it from idle, or your plugs aren't black.
Old Feb 22, 2008 | 03:21 PM
hogdoc's Avatar
hogdoc
ORIGINAL: Jinks
ORIGINAL: hogdoc
ORIGINAL: Jinks
A dyno tune IS a neccessary expense bacause with all the different combo's of parts out there there is no way to make a map that fits all. I have put the exact same parts on 2 bikes (husband and wife's dyna's same year same model )and the maps needed to be very different in many places. You CAN run it without a proper tune, but, your sacraficing fuel mileage, cruising and under load performance, and in some cases your running it so lean it IS damaging the motor. Ever pulled one apart that was run lean for a while? Very hard on pistons and cylinders, and the extra heat generated breaks oil down faster and does long term damage to bearings and races, shafts and bushings, takes out the oil pump, trashes the cam plate, cams and lifters.
Yes a poor tuner can make your bike run worse than it did before. Thats why you dont just drop it off at Joe Shmoes Dyno Emporium to spendthe extra money thats burning a hole in your pocket. Do some research and find a good tuner. He may not be next door, he may be hundreds of miles away, hell he mabe even in the next state. But a good tuner is worth his wieght in gold when you find US. BTW Iam 250#'s so save up!
Old Feb 22, 2008 | 03:32 PM
tom73's Avatar
tom73
The black smoke is from the enrichment of the motor on start-up. The SERT has differnt values for a/f ratio while the engine is heating up. Like Jinks said as long as it is not doing it once it is warmed up. The black smoke usually indicates a rich condition. Mine does it as well.
Old Feb 22, 2008 | 03:42 PM
Jinks's Avatar
Jinks
ORIGINAL: hogdoc
Damn! You must be *GOOD*!.............8^)
Old Feb 22, 2008 | 03:50 PM
hogdoc's Avatar
hogdoc
ORIGINAL: Jinks
ORIGINAL: hogdoc
FNARIGHT!!!!
memphisharley
Jun 15, 2018 10:46 PM
08FXDL
2014-2024 Touring Models
35
Sep 16, 2016 07:01 AM
knucklebucket
Jul 24, 2013 09:25 PM
floridamk
Exhaust System Topics
Apr 29, 2013 08:12 PM
epsorzano
Mar 27, 2009 08:45 PM
