Part #s for 3.37 Primary Gearing
Old Mar 1, 2008 | 07:04 PM
NCCopBikeRider's Avatar
NCCopBikeRider
Default Part #s for 3.37 Primary Gearing
Want to upgrade 3.15 to 3.37
Does anyone have the #s handy (search not working)
Thank You
Old Mar 1, 2008 | 07:55 PM
Harleypingman's Avatar
Harleypingman
Default RE: Part #s for 3.37 Primary Gearing
"The clutch basket part # is 37846-99A 37 tooth. The motor sprocket is #40269-85A 24 tooth."
If you type in "3.37:1" in the "Search" term, you get a bunch of hits; that's where the above came from.
If you go to Chicago HD's website, you can type in those PN's and it will, if they are accurate, confirm the description, and provide pricing.
The gear change uses the same chain as the 3.15:1 set-up.
Old Mar 1, 2008 | 08:02 PM
myzen's Avatar
myzen
When making the change did you buy a new roller bearing as well or re use it? 37906-90 part number
Old Mar 1, 2008 | 08:24 PM
NCCopBikeRider
Pingman
Tried search, however, appreciate the numers
Thanks
Old Mar 7, 2008 | 06:31 PM
NCCopBikeRider
Ordered the parts.
Going to replace the primary change while we are in the primary case.
Thanks
Old Mar 22, 2008 | 05:44 AM
NCCopBikeRider
Upgraded Gearing on 06 Cop Glide to 3.37 to 1
Worth the time and effort. While we were in there, replaced primary chain and tensioner shoe.
Good bang for the buck upgrade using factory parts.
Thanks to all for the assistance.
Old Mar 22, 2008 | 07:25 AM
Harleypingman
Good for you, Tom--glad you like it. I'd like to know how you compare the 3.37 to the 3.15 for two-up riding.
Old Mar 22, 2008 | 12:42 PM
NCCopBikeRider
Will be glad to comment as soon a bike is "road worthy".
Still attemtping to locate all of the repair parts, and get them installed along with the Real Job.
Have a great weekend and a safe Easter
Old Mar 22, 2008 | 02:50 PM
Forget About It's Avatar
Forget About It
is there any gearing options for th 08s other then the evolutionindustries gear
Old Mar 22, 2008 | 06:10 PM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: Harleypingman
I can tell you how I like it....I love it. I have ridden thousands of two-up miles with the bike loaded down with 60+ lbs of gear. At anything about 50 mph, there is no need to downshift. At 60+ MPH, you are right in the "sweet spot". When you crack the throttle, it pulls like a freight train very hard up to 90-95. It is great for making passes without having to downshift.
kswan
Shovelhead
Mar 23, 2012 11:37 AM
WRAITH
Oct 18, 2010 11:48 AM
dognut
Oct 8, 2008 10:53 AM
RangeRat
Sep 5, 2008 12:37 AM
Velocity1
Mar 6, 2008 01:44 PM
