Sundowner problems
Old Feb 2, 2006 | 05:42 PM
brinks13081's Avatar
brinks13081
Default Sundowner problems
Maybe someone out there can help me. I just got my new Sundowner Seat today for my FLHRI. the instructions tell me to remove a mounting bracket from my stock seat and install it on the new seat. The problem is there are no holes drilled in the new seat. I installed the rear bracket that secures the very rear of the seat, but the bracket that is secured in the middle of the seat with the two larger bolts, I'm not able to install. I wouldn't know how to get to them anyway since this is a touring seat (one piece). Any help would be greatly appreciated.
Old Feb 2, 2006 | 06:07 PM
bountyhunter's Avatar
bountyhunter
Default RE: Sundowner problems
Should only have to mount with 1 screw in the rear. About a ten second job.
Old Feb 2, 2006 | 06:34 PM
OG_electra_glide's Avatar
OG_electra_glide
not trying to be a choad, but did you try calling customer service?
Old Feb 2, 2006 | 07:11 PM
Tn.Heritage's Avatar
Tn.Heritage
What he said.
ORIGINAL: bountyhunter
Old Feb 2, 2006 | 07:38 PM
Primo's Avatar
Primo
On my Sundowner the front had a tang that fits into a slot in the frame just in front of the gas tank. On the rear of the seat is the bracket you took off from your old seat that mounts with one screw to rear fender. Which part # seat did you get?
Old Feb 2, 2006 | 07:59 PM
brinks13081
I got the 51617-99C. It does fit in the front slot and it does secure to the back with the one screw. I was just thinking that other bracket from the stock seat would secure to the new seat but there are no holes for it. I don't have the grab strap on and I believe that it is necessary per Harley.
Old Feb 2, 2006 | 08:09 PM
carsoni's Avatar
carsoni
my sundowner didn't have a grab strap either. I used the stock one it's fine
Old Feb 2, 2006 | 08:15 PM
spartns's Avatar
spartns
The grab strap is not necessary, it's your choice. As to mounting, there's only the front tang and the rear bolt. The center brackets that might be mentioned in the instructions would be for the rider backrest.
Old Feb 2, 2006 | 08:16 PM
brinks13081
I guess there isn't a problem then, thanks.
Old Feb 2, 2006 | 08:23 PM
spartns's Avatar
spartns
You're gonna love the Sundowner. Let us know how works out for you.
