Fluctuating Voltmeter
Old Mar 22, 2008 | 09:41 PM
evac14driver's Avatar
evac14driver
Default RE: Fluctuating Voltmeter
How old is the battery, could be a bad cell?
Old Mar 23, 2008 | 08:53 PM
maxum96's Avatar
maxum96
ORIGINAL: evac14driver
Bad battery should not show up on the voltmeter while the engine is running. You can totally take the battery out after the engine is running and the voltage should still be over 13 volts on a car or bike.
Old Mar 24, 2008 | 12:09 AM
robbie52's Avatar
robbie52
I didn't think the voltmeters ever moved. Probably the stator shorting out.
Old Jul 15, 2016 | 07:10 PM
rpmhd1's Avatar
rpmhd1
Stage I
I have a 08 flhtcui and when I start it, it reads 10-11 volts. I have to stop it and turn it back on 2-4 times and then the volt meter reads a little over 14 volts. I hear it might be a ground however where are all the grounds located, any help would be greatly appreciated, on fixed income. thanks
Old Jul 15, 2016 | 07:34 PM
im's Avatar
im
Check your battery cables. The four ends. Two at battery. One at top of starter. One to frame. Just follow the wires from battery.
Old Jul 15, 2016 | 07:47 PM
ORradtech's Avatar
ORradtech
Ground wire at the battery, trace it through the frame to the opening just rearward of the tank. The battery ground goes to one stud. Be sure it's clean and tight. There's another stud in the same area that's also a ground, might ss well check it while you're there. I believe the regulator grounds to the frame with it's mounting bolts, be sure they are tight.
If you read this old thread then you know that the fourm has a troubleshooting guide for the charging system, get a dvom and do the checks.
If you don't have a digital volt meter (dvom) places like harbor freight usually have very basic, but very usable for this, ones for under $5, sometimes even free.
Old Jul 16, 2016 | 08:59 AM
voodoodrug's Avatar
voodoodrug
I sanded the around the bottom of regulator a bit and added a second ground from other location on battery terminal to bolt that holds starter to primary to take some of the guesswork out of the equation.
Fmsplr
Electrical/Lighting/Alarm
Jun 27, 2019 06:51 AM
Fscott4
Sep 1, 2018 11:30 AM
alee18
Jan 8, 2018 01:34 PM
Sauraus
Mar 14, 2017 09:45 AM
nobody05
Sep 21, 2016 08:26 PM
