No brake lights or Cruise Control
Old Apr 3, 2008 | 08:59 PM
LuLu's Avatar
LuLu
6th Gear
Default No brake lights or Cruise Control
I put new hand grips on my 05 RK Classic today. When I got the right controls back together and took it for a ride, I noticed that when I hit the switch (left grip) the red Cruise Control light comes on the console. But when I try to set it with the rightswitch, NADA!
When I got it home and back in to the garage, I noticed no brake lightseither. Foot brake or hand brake. I pulled the fuse box and the fuse look good. Replaced it anyways but still nothing (Cruise and Brake on the same fuse).
Anyone got any suggestions? I took the controlsback off the right side and looked around. All wires look good as do the connections! Do the controls ground to the handle bars? Everything else works! Horn, blinkers, ignition switch, and start button.
Damn.. Supposed to be some nice weather this weekend!
Any help appreciated.
LuLu
Old Apr 3, 2008 | 09:03 PM
dawg's Avatar
dawg
Default RE: No brake lights or Cruise Control
pinch a wire?
Old Apr 3, 2008 | 09:09 PM
ironhead3fan's Avatar
ironhead3fan
Maybe the plug inside the fairing isn't seated properly and the least bit of stress was enough to pull a corner of it away from itself? A long shot, but it would only take a few minutes of puling the front fairing to make sure.
Old Apr 3, 2008 | 09:14 PM
Mathews2's Avatar
Mathews2
If the fuses look good, I have to go with something unplugged. If you severely pinch a wire it will blow the fuse as soon as you hit the brake or tried to turn the cruise on, Don't ask me how I know[8D]
Old Apr 3, 2008 | 09:16 PM
LuLu's Avatar
LuLu
6th Gear
pretty certain I didn't pinch anything. pulled the insallation back as far as I could.
iron..
l'll find the plug you're talking about. would that disable the foot brake light too?
Old Apr 3, 2008 | 09:45 PM
sifularson's Avatar
sifularson
If you broke the brake switch in the RH lever, it will affect the cruise. Is that possible???
Old Apr 3, 2008 | 09:46 PM
Rocket Jockey's Avatar
Rocket Jockey
My guess is your brake light is on all the time and just looks like it is not on. Here is the million dollar question, did you shim the front brake lever when you pulled things apart? If not you probably broke the little plunger switch that controls the brake light and cruise. Don't ask me how I know this.....
RJ
Old Apr 3, 2008 | 09:59 PM
LuLu's Avatar
LuLu
6th Gear
sif.. def possible.
jockey. did not shim that switch. wouldn't even know how.
is the switch replacable or do I have to buy the whole housing?
Old Apr 3, 2008 | 10:10 PM
19114Me's Avatar
19114Me
I had the dealerfix the plunger. I DID NOT follow the directions when I replaced my grips and broke the damn thing and no you do not have to replace the whole housing. Just a $20 part that cost about an hours worth of work. Don't ask me how I know either.
Old Apr 3, 2008 | 10:11 PM
stro1965's Avatar
stro1965
ORIGINAL: Rocket Jockey
RJ
What he said. Exactly.
