HD "pull back bars"
Old Apr 30, 2008 | 05:07 AM
patsac's Avatar
patsac
Default HD "pull back bars"
07 e-glide
thinkin about a set of the h/d pull back bars.they only have a small differents in rise and pull back from the stock bars. iv heard from some that you can install these with out installing longer cables( throttle, brake, clutch )..anybody here installed these using thestock cables?
Old Apr 30, 2008 | 05:17 AM
jhill2209's Avatar
jhill2209
Default RE: HD "pull back bars"
Can't say on an '07, but I did it on an '08 with all stock cables and lines. The clutch cable required rerouting an is at the end of its limit, but it can be done.
Old Apr 30, 2008 | 06:55 AM
rocknrod's Avatar
rocknrod
Idid it on a 08 without replacing the stock cables also.
Old May 1, 2008 | 03:04 PM
patsac's Avatar
patsac
sounds good...anything that i should be aware of?...will i have to adjust the clutch / throttle after?....and the grips..reusable after you took them off?....any insite would be appreciated
Old May 1, 2008 | 03:47 PM
AZ Rider's Avatar
AZ Rider
Do you guys have a part number on that? Been looking at the catalog and can't find it. So many bars they have listed...
Planning on doing this to mine as the '08 RK bars are just too short and low for me.
Thanks.
Old May 1, 2008 | 03:52 PM
lp's Avatar
lp
Just a heads up. I installed those bars with all the stock cables.... I really didn't like them. Too narrow (for me).
Check it out... https://www.hdforums.com/m_1594023/tm.htm
lp
Old May 1, 2008 | 04:09 PM
monkyman's Avatar
monkyman
I installed the reduced reach bars on the 03 Road king, Same cables, brake line had to be bent a little to work. I had ordered the wire harness extension at the same time (same cost as the bars, $50.00[:@]for about a 3" extension). I internally wired the bars and could have gotten away without the 3"extensions, but I used them anyway. Elbows are bent now while riding, much easier on the back.
Old May 1, 2008 | 04:58 PM
rocknrod's Avatar
rocknrod
ORIGINAL: lp
lp
Yep, your right. I notoced the difference in the way the bars come back.
I may have to change out to a Wild1 WO575 next.
Old May 1, 2008 | 05:15 PM
patsac's Avatar
patsac
rocknrod...wish i would have known of this wrist angle befor i went and bought them today lol
sooo im still gonna put them on and see how they like me, any insite you can give me befor i rip into it?
Old May 1, 2008 | 05:28 PM
treeboy97Flht's Avatar
treeboy97Flht
I used the bars and only changed the brake line on my FLHT
