DYNO Numbers for Baggers???
You're kidding right? My goodness...first you're confused about top end speed and now you're going to suggest dyno-tuning "is mostly for peak hp #s". Hardly!! Dyno-tuning ...(unless you're getting ripped -off) is about ensuring smooth throttle response across the power band and maximizing the available torque and HP IN ALL RPM ranges. And yes it should also result in ensuring peak hp is optimized at WOT.
But if you think that dyno-tuning is mostly about Peak HP and WOT then you have alot to learn.
For a guy that supposedly does tuning you seem to have some big gaps in your knowledge. I can assure with absolute certainty that any HD ridden by anyone...and that includes you will have more time spent passing through and operating between 2-3krpms than anyone other range. PERIOD.
I use DJ Powervision for monitoring my engine, logging data runs, tuning etc. From the many dataruns on the PV and the years of data runs I've collected using the SEPST for tuning my other bike, there's is absolutely no doubt in my statement above.
In fact after a 15min run or a 2hr datarun, the primary "hits" of a fuel injected bike's data will be be between 2000-3000rpms and between 20-60 KPa on the throttle.
In fact the hits to the cells in this region will generall be 10x more than any other region of a fuel-injected bike's fuel map (unless your bike only operates at the drag strip).
And I ride my bike hard and the facts are are undeniable. The average guy rides far less agressively than I do and will probably be more like 15x in the 2-3K range vs the rest of the fuel map. Just a simple fact of acceleration and deceleration and if you have lot's of low-end torque you'll spend even more time in this range....even you whether you want to believe it or not. Most newer HDs operate below 3k rpms in 6th gear below 75mph so on the higway, if you run in 6th gear you'll be spending most of you're operating tim between 2-3krpms. Even in the twisties you'll be surprised how many times you drop below 3000rpms as you pull in the clutch and then let it back out. The data is irrefutable.
Like i said, I guess I just worded my responce poorly, I was talking about the info that you see on a dyno printout, Nothing that you see on a 100% throttle run on a dyno represents cruising, that was the point I was trying to get across. Thank you for the kind words.
Being able to pass a truck on a highway (WOT from cruising speed) is a whole lot more convenient when you don't have to drop a gear or at worst, you only need to drop a single gear.
A WOT dyno chart will absolutely show the owner if the tuning has been optimized in the ranges the rider is in most often. In fact after years of reading dyno charts, I have never read one that only started at 3000 rpms...NEVER. Why a tuner would find that useful is beyond me and of no real value to the owner without the WOT performance between 2-3000. And I made no references to wanting to know the performance below 3000rpms because that's where we "cruise". In fact I didn't make any reference other than suggesting it would be good to see the performance between 2-3000rpms. And it would be, which is why every chart on this entire thread starts somewhere below 3000rpms.
Of course the dyno's posted are peak #s at WOT. But wouldn't you want to know if you bike was well tuned so that you could "whack" the throttle from a cruisng speed and not have it stumble or leave ponies on the table? A good tuner should provide the customer with charts at varying operationing levels such as cruising and WOT. And newer bikes (throttle-by-wire) will show the performance in KPa, not TP.
Any time you want to "walk back" your view about Dyno charts is fine by me, but there's no legitimate reason for deleting off the 2-3000rpm range from a peak performance dyno chart. None...which is why no one else does it!
