DYNO Numbers for Baggers???
Old Nov 20, 2011 | 12:06 PM
  #3051
Rich67's Avatar
Rich67
Originally Posted by coolerman69
Hey all i did was post my dyno chart! I cant help that it also shows mph! Maybe I should have used whiteout.
LOL.Maybe You should've.Think it through a little better next time.
Old Nov 20, 2011 | 01:28 PM
  #3052
harleyiron80's Avatar
harleyiron80
Originally Posted by Heatwave
A dyno with speed measured on it tells the owner nothing. Unless that dyno has superfans on it that can replicate a 120mph wind head-on into the bike, that top speed would only be relevant if you could ride the bike in a vacumn.
Remember, wind resistance is exponential and once you're over 50mph, you'll need exponentially more hp for each additional mph to push through even greater wind resistance. That's why mph on a dyno graph are completely irrelevant at anything other than very low speeds.
what happens if the wind is at your back
Old Nov 20, 2011 | 01:48 PM
  #3053
Deuuuce's Avatar
Deuuuce
Just subtract the mph from the air resistance calculation.
I remember this one guy bragging about the 170mph dyno run his Ford F150 HD edition truck did. What a goofball.
Old Nov 20, 2011 | 01:59 PM
  #3054
mtclassic's Avatar
mtclassic
You get better mpg.
Old Nov 26, 2011 | 11:16 AM
  #3055
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Default My dyno results with 255 cams
2012 flhx 103ci
stock heads
stock pistons
s.e. stage one a/c
s.e. 255 cams
v&h propipe
s.e. pro super tuner
91.31 max power
106.02 max torque
Old Nov 26, 2011 | 12:20 PM
  #3056
Heatwave's Avatar
Heatwave
Member
Ya go faster than when it's in your face!
Old Nov 26, 2011 | 07:31 PM
  #3057
ClassicBill's Avatar
ClassicBill
Just got mine out of the shop. 103ci, ported heads, 10/1 pistons, 259E cam. I can't figure out how to put the chart up here so the #'s are 105 hp, 106 tq.
Old Dec 3, 2011 | 06:13 PM
  #3058
Uncle Salty's Avatar
Uncle Salty
Default 2004 Road King
2004 95" Road King, Wood TW6G cam (.510 lift, not the high lift cam), Hillside heads, 9.8 to 1 compression, D&D FatCat, Daytona TT II ECU with no dyno tuning. Tuned to run on decent regular gas. 44 to 48 MPG @ 55 MPH, 40 to 42 MPG @ 75 MPH. 102 HP, 102 lb/ft torque STD.
Old Dec 3, 2011 | 07:47 PM
  #3059
coolerman69's Avatar
coolerman69
Woods cams are now on my wish list! I love that tq line!
Old Dec 4, 2011 | 11:39 AM
  #3060
terryrh's Avatar
terryrh
M'likes. M'like a lot.
