DYNO Numbers for Baggers???
Old Sep 18, 2012 | 08:26 PM
  #3551
Guzz's Avatar
Guzz
Default 2012 Ultra Classic
103" Inch
SE Stage I A/C
Stock header pipe with CAT removed
V&H Twin Slash Mufflers
SE 255 Cam
Just got her back today after 5k maintenance. From seat of the pants, feels good, not overly impressed yet (will take her out longer tomorrow). Seems to gallop a bit right around 1500 RPM. CAT removal made a huge difference in sound/volume (I like it).
Old Sep 18, 2012 | 10:33 PM
  #3552
Rlpro's Avatar
Rlpro
Ok here's mine....Ok so got the bike back from the dyno tuner (they use Direct Link) and went for a good ride. Wow what a difference. She pulls hard all the way through the rpm range. I'm really impressed no popping on decel and way better than Harleys stage 1 flash as you can see on the dyno sheet, blue is before and red is after. Money well spent, I definitely recommend going the dyno tune route. My 2008 Electra Glide Ultra has screamin eagle stage 1 air kit and vance and hines oval slip ons on it.
Old Sep 20, 2012 | 04:51 PM
  #3553
porterjohn's Avatar
porterjohn
Stage I
Default 2012 Street Glide Tequila Sunrise
Vance&Hines header pipe, rhinehart mufflers, screamin eagle air intake, 255 cams, screamin eagle programmer, 93 H.P. 111ft lbs torque dyno at Route 66 HD Tulsa,OK
Old Sep 21, 2012 | 06:21 AM
  #3554
rodney123456's Avatar
rodney123456
i see you have the se air intake are you using the k&n filter the kind you oil in it? If so do you have oil leaking out of it?
Old Sep 23, 2012 | 04:55 AM
  #3555
Streetin's Avatar
Streetin
Got bike on dyno for the first time. Numbers seem pretty average for a stage 1.
2009 Street Glide
96"
FM A/C
PCV
CFR slip ons
Stock headpipe
76 hp
88 tq
Old Sep 23, 2012 | 08:31 AM
  #3556
Kevinoffroad4x4's Avatar
Kevinoffroad4x4
Did a baseline pull of where my 2006 streetglide is at before I install my 95" big bore.
88"
Rinehart true duals
K&N highflow
Power Commander III
74hp/76tq
Old Sep 25, 2012 | 12:12 PM
  #3557
RoadGlidinFreak's Avatar
RoadGlidinFreak
All the torque right where I normally ride when I'm in cruise mode from 2000 to 3000... but will still run pretty decent on topside
Old Sep 25, 2012 | 10:32 PM
  #3558
Pastor Ed's Avatar
Pastor Ed
2010 FLHTCU Blue
4,547 miles
Sept. 25, 2012
................96 cu in............103 cu in.....Difference........% increase
HP...............61.36................97.78....... ...36.42................60
Torque.........77.62...............108.49......... .30.87................40
I will try to make a sharable copy of the Dyno results that show the before and after.
Last edited by Pastor Ed; Sep 26, 2012 at 09:46 PM. Reason: Numbers collapsed together and didn't make sense
Old Sep 28, 2012 | 11:10 AM
  #3559
whetsel.m's Avatar
whetsel.m
124", woods 408-6, 128/145
Old Sep 28, 2012 | 06:43 PM
  #3560
producer's Avatar
producer
Pastor Ed,
That's a nice bump! Did you do any head work when you had the thing apart? I'm breaking a rule here with this next question; If you did or did not, what's your average MPG now?
Originally Posted by Pastor Ed
2010 FLHTCU Blue
4,547 miles
Sept. 25, 2012
