I am new to HD, so NOT real familar with all the abreviations. I'm getting a 2013 street glide, and I'm looking for some info on a good exhaust system for the 103. I'm planning on getting a full exh system, a tuner, and the air cleaner. And maybe cams... MAYBE! depending on how much it will cost. So if anyone riding a new street glide w/ 103 has any info to share I would greatly appreciate it!
Check out Fuel Moto (site sponsor). If you call them and tell them what you want for power upgrades, they will be able to dial you in nicely. Whether you want mild or outrageous, you are in good hands with them. Here is a link: http://www.fuelmotousa.com/
Thanks
Just added a new 2012 FLHX w/ 103 to the stable and have Fullsac pipes, 254e cams and TTS on order. I have the 255 cams new in the box but decided on the 254e instead has I had them in another bike I had and like the performance better over the 255.
I have a 2012 FLHX that was just dyno tuned. I have V&H Power Duals with Rinehart 3.5 slips, Stage 1. Mine hit a max of 75.8HP/94.00FTLB. After looking at posts with folks having cams, more mods, etc., and not hitting what my bike hit, I'm pretty doggone happy. I think I'll just leave it alone. My baseline prior to dyno tuning, but with the mods was 66.06HP/75.08FTLB. the guys at the dealer say that it is unusual to get such a nice jump in torque. They said they usually see about 10-12FTLB. I'm stoked...
I'm about to pull the trigger on a stage 1 for my 2012 FLHX. I'm going to do a SE Heavy Breather, Tmax w/ Autotune and either a Dragula 2 into 1 or a D&D(leaning more towards the Dragula, cheaper and has ceramic coating inside and out). Anyone know what kind of numbers I should expect to see with this setup?
5-7% better than stock torque and HP numbers. Post them when you find out.
Thanks
IMO, best money you can spend is on a Stage 1 kit and a 30T transmision pulley, followed by a Thundermax ECM with Autotune. Then Cams..
