DYNO Numbers for Baggers???
Old May 15, 2013 | 08:10 PM
  #3981
EdandGrace's Avatar
EdandGrace
Default upgrades tomorrow
13 Street Glide upgrading to stage 1 air with Rush true duals, 4 in. Big Louie with 2 in. baffles, SERT and dyno. What numbers can I expect? Thanks.
Old May 16, 2013 | 06:48 AM
  #3982
Softy 103's Avatar
Softy 103
Originally Posted by Badking99
99 roadking,
95 ci
Se pistons
Woods 8g cams
Se heads/intake
Mikuni carb
Se big sucker
Thunder header
Few other mods stock bottom end
Hp 101 to 110 roughly
I think my bike can out run yours on the the 101 hp. days , but it will be a battle on the 110 hp. days. Just curious does your Tq. vary that much also?
Old May 16, 2013 | 07:24 AM
  #3983
wild1s2's Avatar
wild1s2
Default 06 streetglide
Back over the winter I had my engine bumped up to a 95 ci. , S& S 570 ez start cams,some mild porting on the heads...95.3 hp and 95.9 tq. The builder picked the cam, not sure if it's the best choice, but it sure will get up and go now.
Old May 16, 2013 | 08:19 AM
  #3984
Blind1's Avatar
Blind1
I have 07 HD FLHX built up to 103" w/SE255 Cam, TTS Tuner, SE Heavy Breather, V&H Radus 2N2 exhaust
HP 107.6 TQ 108.2
Old May 16, 2013 | 08:40 PM
  #3985
stogieluvr60's Avatar
stogieluvr60
Default Really.....
HP 107.6 TQ 108.2
107.6 Hp with 255 cams......now thats impressive! You wouldn't happen to have a dyno sheet of this would you? That's an awfully high number for 255's is all. I have a 103" with 255's and I would love to know your secret! Thanks!
Old May 16, 2013 | 08:42 PM
  #3986
stogieluvr60
I'm guessing low 80's hp and low 90's tq....ballpark. Needs cams to open it up. Stock cams are for emissions not performance.
Old May 16, 2013 | 10:10 PM
  #3987
mtclassic's Avatar
mtclassic
most 255's make under 90hp and around 100 ft/lbs in 103's so yea this one must have some major head work or some secret sauce.
Old May 17, 2013 | 02:11 PM
  #3988
CoachJR's Avatar
CoachJR
Just got mine got my 255s, Dyno tune, and back today. With the set up listed in my sig...
Max HP 77.05 @4500rpm
Max TQ 99.26 @2800rpm
Old May 17, 2013 | 02:45 PM
  #3989
producer's Avatar
producer
Yeah me too! I think everyone would throw there Andrews 26 and 37's in the garbage if this is true.
Old May 18, 2013 | 10:11 AM
  #3990
Unbalanced's Avatar
Unbalanced
HP 107.6 TQ 108.2
Do you have a dynosheet with the correction factors to backup the numbers that you can post?
110's with headwork by TMan and Doc1 tuning arent even seeing that kind of hp with 7 extra cubes and good pipe combinations.
