I just had my bike on the Dyno last Sunday at Faribault HD after a major build
Jason At Faribault really didn't believe it was a 103 CI motor after the first pull. Tony and Rocky at Rocky's Custom Baggers did an amazing job on the motor. We pulled 130.5 Hp and 126 torque. Jason at Faribault HD is a great dyno tuner also. Were using Freedom true duals for exhaust. It's an animal!
Thanks for the heads up. I live in North Central Iowa about 2 1/2 hours or so south of Faribault. I have heard good things about Jason as well.
i have an 07 flhtc with se air cleaner an rhineheart slipon mufflers an se race tuner, it made 78.5 hp an 84.69 torque. then i put feuling 525 reaper cams in and made 86.15 hp an 92.56 torque.
Just got my final dyno tune done after breaking in my rebuild. 2000 FLHT standard. 95" big bore, with ported and polished heads. 10.5 to 1 Comp, Stage 1 airfilter, Andrews 37 cams, Stock Carb with Dynatek ignition, Klock werks 4" Slip ons.
just ordered an S&S 106 with Chris Rivas 574 rocket cams. Will keep you posted once its done and dynoed.
Just got this back from the shop the other day and it goes like a raped ape. Still have to break it in before they can fully dyno tune it. Any guesses on TQ and HP. Im guessing/hoping for 105 TQ +/- 2 95 HP +/- 2. Bike has a pro pipe and PCV.
everyone here is pulling some good numbers!! just trying to get a feel for where u guys think i might be. bikes in the shop having all this done so just trying to get a close estamate from you guys.
2000 roadking doing the s&s 95 hot set up ( s&s heads, 10:5-1 comp, 585g cams, true dual rineharts, s&s super g carb, s&s intake, s&s manifold,) also had my crank rebuilt by r&r in manchester ( balanced, pined, welded) bike was also converted to chain drive before me not a fan of that but im gunna run with it to see if i like it or not. Just looking for where u guys think ill be at Thanks
Should be just over the 100/100 mark. The 585 has good numbers really good with heads..
