DYNO Numbers for Baggers???
Old Jun 21, 2013 | 08:39 AM
  #4081
EdandGrace's Avatar
EdandGrace
Originally Posted by stogieluvr60
Those #'s look about right, the stock cams hold back your hp. The torque # looks good. Any chance you can post the dyno sheet so we can see the curves? Thanks for the update though!
Don't have a scanner. Will try and take a picture. What numbers do totally stock bikes show? I'm thinking I may have picked up close to 10%?
Old Jun 27, 2013 | 12:58 PM
  #4082
baggerbrent's Avatar
baggerbrent
V&H power duals
V&H hi output slipons
SERT
103" stage 4
105Hp. 108Tq
Old Jun 27, 2013 | 09:01 PM
  #4083
stogieluvr60's Avatar
stogieluvr60
Default My apologies.....
Originally Posted by wataskia2000
Finally got her on the dyno the other day. 109 TQ and 101 HP. The torque dips just after 3000 then comes back at 4000 and they couldn't tune it out. Im thinking its the Pro Pipe, may try different baffles.
Somehow I missed your post about your dyno results......honestly, I thought you would see better numbers but in the end you can't ride a dyno sheet.......curious as to what has happened with it since May.....any changes?
Old Jun 30, 2013 | 10:01 PM
  #4084
quickster's Avatar
quickster
Default Dyno #'s
I think this is about all I can get out of her. Thanks to Ken at Black Hill's Customs
2000 SERG
97" S&S Forged pistons
Dewey Pro street heads
HPI throttle body
Andrews 37G cams
Freedom Performance 2 into 1 Union pipes
106 HP
108 TQ
Power commander
Old Jul 2, 2013 | 02:46 PM
  #4085
Snake1973's Avatar
Snake1973
4th Gear
Default Bagger dyno numbers
I have a 05 flhtci. 95" s&s gear cams,screamin eagle heads,HD. Heavy breather,vance and hines big radius 2:2. 89hp,96tq
Old Jul 2, 2013 | 09:57 PM
  #4086
MCMXI's Avatar
MCMXI
Originally Posted by Virongoosh
Same basic setup I was planning to get on my 2012. How do you like the sound of your exhaust system?
Sorry man, haven't checked the forum in awhile. We had a few good storms blow through that kept me working...a lot.
The exhaust sounds awesome. It's a nice deep, mellow tone at idle and let's you know it means business when on the throttle. I went with the standard baffles, but I may switch to the Competition baffles when I do the heads to get a little more sound out of her.
One thing I didn't list was an AIM lock-up clutch. I was running Amsoil, which Jamie said was no good in the primary with the power; too much slippage. I had them install the AIM while they had it tore apart, which will hold the power all day. He stressed non-synthetic oil in the primary.
Old Jul 11, 2013 | 05:53 AM
  #4087
MaineRyder's Avatar
MaineRyder
86.05hp & 101.67tq ... V&H dresser duals, hi flow air cleaner, power commander V and TW222 cams other then that bikes engine is bone stock and fun to ride, makes some nice power down low and pulls good with 90lbs of tq starting at 2200rpms.
Attached Thumbnails  DYNO Numbers for Baggers???-dyno-tune-6-10-13-660-x-480-.jpg
Old Jul 11, 2013 | 09:18 AM
  #4088
rogersm's Avatar
rogersm
6th Gear
Well im pretty pumped after seeing all these dyno sheets and the curves. My little 110 laid down 128tq and 117 hp with some ported heads, 584 cams, S&S flywheel, thunderheader and stock intake and tb. I will have to find someone to scan the dyno sheet and then ill post it up.
Old Jul 14, 2013 | 05:23 AM
  #4089
cpws31's Avatar
cpws31
Stage II
Default 2013 street glide
I was very happy with these numbers!
Attached Thumbnails  DYNO Numbers for Baggers???-2013_street_glide_dyno_sheet.jpg
Old Jul 15, 2013 | 07:22 PM
  #4090
stogieluvr60
Default Damn!
2000 SERG
HPI throttle body
Andrews 37G cams
106 HP
108 TQ
Power commander
I'll say it again......DAMN! that thing pulls and pulls! Hold that 100+ ft lbs way passed 5000 rpms and all that hp catches up........gotta be loads of fun to ride! You gotta be proud! Congrats! What's your impression of that Union pipe? Not a lot of people posting results with that pipe......looks good!
