DYNO Numbers for Baggers???
Old Mar 1, 2017 | 12:45 AM
  #5511
DeneFXDWG's Avatar
DeneFXDWG
Originally Posted by BrownSanta
Fuel Moto​ High Output 107...
-Forged 11.0:1 CP Carrillo pistons
-Fuel Moto Extreme Duty Cylinders
-Fuel Moto Level C CNC ported heads 1.9/1.6 valves
-Wood TW999-6 Camshafts
-Wood alpha directional lifters
-HPI 58mm throttle body
-5.3g fuel injectors
-Aim variable clutch pressure plate
-D&D Fatcat exhaust
-Dynojet PowerVision
Please say you forgot to write down the improvements to the crank etc?
Old Mar 1, 2017 | 07:59 AM
  #5512
ucbruce's Avatar
ucbruce
Yeah, with that much power you have to rebuild the bottom as well. With major improvements to the top end you better strengthen the bottom end or you risk catastrophic failure. A lot of people are going to chain final drive on the big builds as well. I know one guy who couldn't keep a belt on his bike, but he had a Pro Charger....
Old Mar 1, 2017 | 09:38 AM
  #5513
randy04eglide's Avatar
randy04eglide
5th Gear
Default Dyno Baggers
103 dyno
I'm running stock pistons and heads, changed air cleaner, tuner and installed fuel moto reaper cams 543 intake and 553 exhaust. 2012 Electra Glide Limited. Gutted cat stock gutted mufflers. Start of dyno session at Smith Brothers Johnson City Tenn. 87 H.P. 97 F.P.T. running very lean. End results 103H.P. and 111 F.P.T.
Old Mar 1, 2017 | 07:06 PM
  #5514
Tn.Heritage's Avatar
Tn.Heritage
Post a picture of the dyno sheet, we like to see them !!
Old Mar 1, 2017 | 08:13 PM
  #5515
Longridertx's Avatar
Longridertx
This is a 103? I would like to see the dyno sheet as well. The final numbers look really high to me for basically just a cam change and tune on a 103.
Old Mar 2, 2017 | 04:28 AM
  #5516
Tn.Heritage
Longridetx I hear what your say'n but it is attainable if the combo comes together along with a good tune, I wouldn't have thought though gutted stock mufflers would do those numbers but still like to see the sheet just the same.
Old Mar 2, 2017 | 11:58 PM
  #5517
DeneFXDWG's Avatar
DeneFXDWG
Definitely qualifies for the term, "budget build", eh?
Old Mar 3, 2017 | 09:36 AM
  #5518
randy04eglide
5th Gear
Default 103 dyno
I really need to replace those gutted pipes to bring my torque curve back down to around 2000 R.P.M., but I'm going to run it this season and see if I like it. I wanted to see what we could do without spending a fortune on heads and pistons. been there and done that before.
Old Mar 3, 2017 | 10:07 AM
  #5519
HotVrod's Avatar
HotVrod
Roeders Racing say that 100hp is easily attainable with cams, tune and pipes with the stock 103... They got mine to 87hp with pipe and a tune..
Old Mar 5, 2017 | 07:06 PM
  #5520
ucbruce's Avatar
ucbruce
Default 100 HP with Pipe & Tune
I think that's tough, but cams make a huge difference. I have a 103 with a full Stage IV race kit, heads, cams, pistons, pushrods, 58mm throttle body, injectors, SE Pro tuner and I got 104 HP & 102 TQ...that's real numbers, not with the tuner sitting on the bike or a manipulated drum...a Stage 1 build will sure open up a stock bike, but you're not going to get triple digit numbers without the cams...
