DYNO Numbers for Baggers???
Old Dec 15, 2007 | 05:28 PM
  #631
msh134's Avatar
msh134
Default RE: DYNO Numbers for Baggers???
rinehart true duels,race tuner,arlen ness ac,andrews 26hcams. i am now off the meds and the cams that we installed were andrews 26h's according to my work order
[IMG]local://upfiles/19879/812DC494A766439D8716C429CCD99A4E.jpg[/IMG]
Old Dec 16, 2007 | 09:18 AM
  #632
seldyn1's Avatar
seldyn1
Just installed SERT and big sucker with no pipe change on my '07 Road Glide.
Max HP 73.09
Max Torque 82.04
I'll try to download my paper.
Old Dec 16, 2007 | 11:10 AM
  #633
terq88's Avatar
terq88
Stage II
I am getting ready to get some new pipes put on and have been talking to people about SERT VS power commander. I am sooooo confused. I am new at this and trying to understand. I am also going back and forth on reinhardt slip ons or the tru duals. Heard good and bad about each. What is best for my '07 road King? And also is it true if I go with the power commander, my warrantys will be voided?
[IMG]local://upfiles/49053/EAAD6FA17D36493995273AC5D717E607.jpg[/IMG]
Old Dec 16, 2007 | 03:11 PM
  #634
iclick's Avatar
iclick
ORIGINAL: terq88
You might want to post this question here:
https://www.hdforums.com/forumid_264/tt.htm
You might also want to check this out. I'm running this combo and it is an excellent option, IMO.
http://fuelmotousa.com/rush_fuelmoto
Old Dec 17, 2007 | 03:30 PM
  #635
diamondheadglide's Avatar
diamondheadglide
Have 07 SG with Rinehart TD, K&N a/c kit, and sert
Max Power= 70.7
Max Torque = 88.7
kinda disapointed in the #'s but boy does she sound and respond better
Old Dec 17, 2007 | 07:47 PM
  #636
bobbyg12's Avatar
bobbyg12
Hi all, I'm new here, really found this to be an interesting and informative thread.
My info:
2006 FLHTCI 88"
SE Stage 1 kit
SERT
25 degree injectors & d/l
80463 HD Catalyst touring mufflers
SE TC 88 Hi Compression 1450 pistons (9.5:1)
SE 211 Cam
85 ft-lbs peak @ 4000 rpm
82 hp peak @ 6000 rpm
Very smooth performance compared to stock...
Old Dec 18, 2007 | 07:46 PM
  #637
maineultraclassic's Avatar
maineultraclassic
ORIGINAL: msh134
rinehart true duels,race tuner,arlen ness ac,andrews tw29 cams.
When you emailed me, you were getting Andrews 37 cams.............there is no such thing as 29's.
Steve
Old Dec 19, 2007 | 10:39 AM
  #638
OldPhat's Avatar
OldPhat
2007 FLHRS 96 inchS.E. Air CleanerAnd
Python Slip-On Mufflers WithA S,E.R.T,
At 4500 Feet Above Sea Level
70 HpAt Rearwheel 4800 R.P.M.
88 Ft. Lb. Tq. At Rearwheel 3200 R.P.M.
Old Dec 19, 2007 | 07:47 PM
  #639
nearmiss's Avatar
nearmiss
ORIGINAL: bigdognc
2007 Ultra Classic EG, 103 Cu In, Wiseco 10.25:1 Pistons, S&S 510-G Gear Driven Cams, Reinhart True Duals, with Standard Baffles, and Power Commander III.
Max HP= 97.44 Max Torque= 111.87 (Real Flat)
How much time did they take to tune it? I live in Raleigh and may want to try them?
[IMG]local://upfiles/33632/A74277EB9E86401E8211E9634B240BB4.jpg[/IMG]
Old Dec 19, 2007 | 11:10 PM
  #640
bigdognc's Avatar
bigdognc
So, they charge you fro 5 hours, but I think it only took him about 3-4. Was done at Iron thunder on spring forest near atlantic springs road. Another good indy is supposed to be Bikers Blvd, on Glenwood.
