2009 CVO Road Glide
V&H Power Pipe
V&H slips ons
heavy breather
CS Download and Dyno Tune. (By Dealer)
Max Power. 93.22
Max Torque. 114.4
Im a little disappointed should i be?
you're about 10 ft lbs. and 10 hp over stock...not a terrible gain but there's probably a little more if you got a good tune somewhere besides the dealer. Only you can decide if you want to spend more money. For reference I have an 08 cvo rk with Rhinehart true dual stepped header complete system and a 58mm throttle body stock cams with a dyno tune by a really good dyno guy and I'm at 103hp and 117 tg.
2009 CVO Road Glide
V&H Power Pipe
V&H slips ons
heavy breather
Max Power. 93.22
Max Torque. 114.4
Hell yes you should be disappointed !
The numbers are inflated by doing a 5th gear reading .
True Dyno Reading are done in 3rd gear lol
I have a 95 ci making 97hp and 101 Tq .
on a 03 Ultra .
I see No Need to buy the new Crap the Factory is putting out !
Reason: Miss Spelling
on a 03 Ultra .
Interesting, I never heard 3rd gear, usually 5th or 6th, but quite frankly 6th gear makes NO sense to me. 5th gear is the "pulling" gear and where I get my top speeds, not 6th which is more of an "overdrive". I can do 120 in 5th gear with 1,000 RPM to go. In 6th gear I'm capped at 110 and 4,000 RPM, with a wide open throttle...
dyno runs are typically run in the 1:1 gear ratio. Which is 5th gear on a 5 speed and 6th gear on a 6 speed. All my dynos are run in 5th unless noted on the sheet. I've never heard 3rd was proper.
on a 03 Ultra .
