DYNO Numbers for Baggers???
Old Oct 2, 2008 | 05:54 AM
  #921
soundman's Avatar
soundman
Bone stock 08 Ultra Classic
96" TC
66.42 HP
83.11 TQ
After addind SE/AC, SE 211 cams, Supertrapps 2:1 supermeggs(20 discs), SERT and dynotuning:
91.01 HP
93.63 TQ
Old Oct 2, 2008 | 10:24 AM
  #922
kbear's Avatar
kbear
Default RE: dyno numbers for baggers.
Originally Posted by GlideMan
Nice work man! I have a build close to yours going on right now and should be wrapping it up and tuning it with a T-Max tomorrow. I have a few more cubes @ 107" and up'd the injectors as well, but all in al should be close. Will be posting numbers real soon.
Interested in your numbers. I am at the 100+ on mine I think with the same approximate build. Carbed with larger jet and compared to stock that is what it feels like. My buddy with the same build in a RK, with the pistons done, Wisco I think?, outruns me but not by much. His was dynoed at 113. Surprised him but could be his riding. I will have to get mine done once I redo the motor mount and put in a stabilizer and new brakes. Too much road wookie. I've tightened up the mount twice but it isn't holding. Seems to shake loose.
Interesting post thanks.
Old Oct 2, 2008 | 02:27 PM
  #923
MAG's Avatar
MAG
Thumbs up
2008 RoadGlide Samson Calier 2:1 SE stag1 SERT 73hp 87tq
Old Oct 5, 2008 | 07:23 AM
  #924
ffb's Avatar
ffb
if i remember it correctly, ( i have my records in another house ) , my 0 street glide 96 cu in motor,
went from stock up 7 hp
and the torque went up to 93.
did the powwr commander ,actually to get a cooler running engine
did the rb black hole exhaust but here the gain was minimal
actually , i would have kept it all stock because the gains for the $'s spent are not significant. and with only the addition of the power commander to keep the engine cool running was sufficient.
Old Oct 5, 2008 | 07:24 AM
  #925
ffb's Avatar
ffb
the above should read 2007 street glide
thr rb black hole is a 2 into 1 unit ..very hi quality .
Old Oct 5, 2008 | 12:41 PM
  #926
pulpfiction1's Avatar
pulpfiction1
03 ultra,95",alum flat top hi-comp pistons,se 258 cams,nightstalker exhaust,breather,Power comander 3 USB.
http://i365.photobucket.com/albums/o...O03ULTRA-1.jpg
can see it runnin here
http://www.youtube.com/watch?v=VVE35YiQaM0
Old Oct 6, 2008 | 01:33 PM
  #927
2whlr4life's Avatar
2whlr4life
I'll be back tonite when this Forum speeds up (hopefully), really slow now.
Gotta get the scanner up too. I have a dyno sheet Baseline for my stock 2007 RoadGlide.
And one for after my mods. A FatCat D & D 2 into one, S/E aircleaner with a k& N filter.
A PC III usb mapped by FuelMoto for these changes. Off to werk...
Old Oct 7, 2008 | 02:32 AM
  #928
2whlr4life's Avatar
2whlr4life
Default Stock vs. upgrades with Dyno run charts
2007 Roadglide stock max hp-65.4 max torque-82.0 (ft-lbs)
added; D & D 'FatCat' 2 into 1 with quiet baffle, S/E aircleaner with a K & N filter, PC III usb mapped for these changes.
max hp-73.9 max torque-86.4 (ft-lbs)
A very noticable increase of 8.5 hp & 4.4 (ft-lbs) of torque and it sounds great! I want more!
Attached Thumbnails  DYNO Numbers for Baggers???-dyno1001.jpg    DYNO Numbers for Baggers???-dyno2001.jpg
Old Oct 11, 2008 | 07:42 PM
  #929
rocknrod's Avatar
rocknrod
Stock 96" engine.
True Duals (fulsac on one side/samson on the other, cause samson sucks)
B&E 2" Mufflers
Ness Big Sucker AC
Before = 64 HP - 94 ft. Lbs. torque
After Tune = 70 HP - 101 ft. lbs. torque
Got it done last night at the Dyno Difference in Richardson, TX
No flat spots anymore and it does sound different.
Im happy with the way it moves all the way through the power curve at every gear.
Old Oct 12, 2008 | 09:53 AM
  #930
badbag's Avatar
badbag
After the 107 cylinder heads, 2.20 intake/1.7 exhaust valves. Redshift 657 Cams, Bassani True Duals:
95.26HP
107.65 Torque
Was expecting 115-120 HP. We think it needs more fuel to get there, so I just ordered a new SE Throttle Body and Hi Flow injectors. Will install and Dyno again this week.
