DYNO Numbers for Baggers???
Old Nov 25, 2008 | 05:21 PM
  #961
texblues's Avatar
texblues
Stage III
Default 2006 95" RG Dyno
SE 95" Pistons
Seasoned Jugs
Mid Comp (On purpose)
Andrews 55G
Mild Head Work (Port clean up)
Jims Lifters
SE Beehives
SE Air Cleaner
TTS Mastertune
V&H Dresser Duals
V&H Slipons 4" - Changing to FuelMoto Jackpots
Dyno @ Horsepower Express - Bruce is a great tuner, too many years of experience and made it run just how I like it. Not after big benchrace numbers, or peak numbers but rideability, and enough to get out the way. Ride 2 up all the time.
TQ-91
HP-93
12.20.08 Changed to FuelMoto Jackpot Classic Mufflers. They sound 100% better, just got that right vibe to them, make you want to twist more!. I don't have any dyno results, but feel more bottom end/midrange. He's got the secret formula here!
Old Nov 26, 2008 | 03:57 PM
  #962
reese's Avatar
reese
I definitely have not read all of the posts but it looks like the 211 cam is a large factor in upping the numbers.
Old Dec 8, 2008 | 04:20 PM
  #963
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
89 HP
108 lb-ft torque
98" Millenium jugs
Stock heads sent to GMR for valves, porting, chamber work
Wiseco forged moly slugs 10.5:1
Woods Cams 575 lift set to stock cam timing
1.675:1 roller rockers
S&S gear drive PCIII USB with custom map, stock ECM, stock MM fuel injection
SE air cleaner
V&H true duels with fishtails
Old Dec 13, 2008 | 01:03 AM
  #964
startin over's Avatar
startin over
Default 06 rk dyno base line run
just got my bike back, what a difference. the shop wants me to put around 300 miles on it and then bring it back for a final tune, said they got it running alittle fat for the break in, so the numbers will probably change alittle when they fine tune it.
woods TW6HG cams
JE pistons
WPC heads 1.900/1.610
Rinehart TD's , se air cleaner, sert. 93.18 HP- 97.12 tq ``
Old Dec 13, 2008 | 11:09 AM
  #965
DoomBuggy's Avatar
DoomBuggy
I just got mine back, Illinois Harley tuned it for me. My request was torque from 2,200 to 3,500rpm, cool running motor, no knock on gentle acceleration. The numbers are not real high, but the torque band is very wide right where I ride at. I am very happy with it right now.
'08 Ultra
SERT
SE A/C
FullSac True Dual Conversion
48 State CVO Mufflers
81.5 Tq
69.2 Hp
Old Dec 13, 2008 | 11:31 AM
  #966
Gearhead1's Avatar
Gearhead1
Default Dyno #'s
2006 Ultra, 95" Stage 2 kit, SE pipes, SERT mapped for fuel milage over performance, no head work, stock injectors
max HP 77.18 @ 4800 / 5500 RPM, max torque 92.59 @ 3700 RPM
Old Dec 13, 2008 | 08:12 PM
  #967
chl11's Avatar
chl11
3rd Gear
I have an 06 RK, Power Commander, HD Heavy Breather, V&H dresser duals W/ fishtails, & just installed Woods gear drive cams (.510 lift), Fueling high capacity oilpump & Fueling lifters. I went for a 200 mi ride today, and got 28 mpg. when running around 78 mph. I was getting about 42 mpg under same conditions before cam install. I love the newfound power, but I would like to get back some ot gas mileage. I am trying to tune in better mileage myself right now, as I have to get over the cam install first before I can afford a dino-tune. Does anyone have a map that is producing good or decent gas mileage with a similar setup?
Thanks,
CHL
Old Dec 13, 2008 | 08:35 PM
  #968
jcbpa's Avatar
jcbpa
Have a 107 with about 95 hp and 100 torque. Not happy yet.
Old Dec 14, 2008 | 07:53 PM
  #969
ripper43's Avatar
ripper43
I just had the 103" stage IIII done and it is 112 hp and 117 of torque not bad but, I think a little more time on the dyno and those numbers can improve.
Old Dec 14, 2008 | 08:00 PM
  #970
jcbpa's Avatar
jcbpa
That is pretty amazing if you ask me! Wow!!!!!
