DYNO Numbers for Baggers???
Old Apr 12, 2007 | 06:51 PM
  #461
MattMeaz's Avatar
MattMeaz
Default RE: DYNO Numbers for Baggers???
07 EGC
D&D Sip-ons
Ness Big Sucker
Sert #78
max power=80
max torque=94
Old Apr 12, 2007 | 08:05 PM
  #462
Indianspringsaz's Avatar
Indianspringsaz
ORIGINAL: MattMeaz
07 EGC
D&D Sip-ons
Ness Big Sucker
Sert #78
max power=80
max torque=94
Dam, those are huge #s,
Whats a SERT #78?
Old Apr 12, 2007 | 09:05 PM
  #463
JBBOOKS's Avatar
JBBOOKS
2005 Road King Classic. TC88, SE AC, PCIII, V&H Duals and Ovals.
73 HP 77 TQ.
Charts and more information, including chart before Duals installed arehere:
https://www.hdforums.com/m_1495826/m...tm.htm#1495943
Old Apr 13, 2007 | 01:36 AM
  #464
RedBarron59's Avatar
RedBarron59
ORIGINAL: Indianspringsaz
ORIGINAL: MattMeaz
07 EGC
D&D Sip-ons
Ness Big Sucker
Sert #78
max power=80
max torque=94
Whats a SERT #78?
2007 Screamin Eagle Race Tuner map for Touring Models
Old Apr 13, 2007 | 02:21 AM
  #465
Indianspringsaz
Thats one hell of a canned map[&:]
Old Apr 15, 2007 | 08:07 AM
  #466
Helmetbolt's Avatar
Helmetbolt
Don't know where you all get you numbers from.?
I have an 05 Ultra
SE Performance heads with compression releases.
1550 Barrels.
1550 S & S flat top pistons.
SE 204 cams
Adjustable pushrods
Power commander 111.
V & H Tru-duels with SE mufflers.
Had it mapped & Dynoed yesterday.
59.67 bhp & 83.13 torque.
Where did I go wrong..???
Old Apr 15, 2007 | 03:44 PM
  #467
liquiddeputy's Avatar
liquiddeputy
ORIGINAL: Helmetbolt
I have an 05 Ultra
1550 Barrels.
SE 204 cams
Adjustable pushrods
Man, I'd be upset if I were you... did you enable Rev-Xtend? Are you spraying so much fuel that there's a puddle behind the bike? Were you on a reputable dyno at a reputable dealer? What curve are you using? Who did the work? That type of build should be pushing numbers like 80/90, not 60/80!!! I'd recommend another dealer, or a compression check, or something... somethin' ain't right. Any other data/performance impressions you can post???
Old Apr 15, 2007 | 05:55 PM
  #468
heavy K's Avatar
heavy K
well i got my dyno numbers back 69.11 max power and 82.49 torque. improvements listed below. i guess i'm alright with the hp number,,,,thought i might get 72 but the torque number seems very low,,,i thought i should be at 92. can anyone tell me their thoughts on these dyno numbers? .................the other stats are,,,,,temp75/humidity 5%....SAE:098<<<<<--i dont know what that means. the slip ons are last years non EPA model,which i was told are much better than those which are currently available
Old Apr 15, 2007 | 09:34 PM
  #469
rhino49er's Avatar
rhino49er
07 ECG...
103" big bore
SE 211 race cams
SERT
Pro pipe 2 into 1
power - 87.5
torque - 101.4
[IMG]local://upfiles/21771/4C15B08C0CDB4A72BBE563056CDAA84A.jpg[/IMG]
Old Apr 15, 2007 | 09:50 PM
  #470
RedBarron59
ORIGINAL: rhino49er
07 ECG...
103" big bore
SE 211 race cams
SERT
Pro pipe 2 into 1
power - 87.5
torque - 101.4
Rhino, Stock heads and head gasket? Did you happen to check you deck heigth?
