mp3 CD issue - still...
Old May 27, 2008 | 03:09 PM
  #31
driesb's Avatar
driesb
Default RE: mp3 CD issue - still...
ORIGINAL: jayman720
I'm SO glad that people are replying to this now. Is there anyone in the Milwaukee area that doesn't have this problem, that I could get a CD to - to see if it's a problem specific to SOME radios?)
What you can do is send me some of the files that will not play on your machine. I will then burn on a CD and try 'em here?
If you want you can send them to dries@bessels.org
CU
Dries
Old May 27, 2008 | 03:52 PM
  #32
Merlin's Avatar
Merlin
Try MP3Checker on the files that cause problems.
Actually, try it on ALL your MP3 files
http://www.download.com/MP3-Checker/3000-2141_4-10543407.html?tag=lst-1&cdlPid=10543408
FREE!
Old May 28, 2008 | 12:23 AM
  #33
jayman720's Avatar
jayman720
I'd love to try mp3 checker - however - I'm a Mac user - so that's a no go.
The 150 song mp3 cd didn't work. This is driving me insane.
In reiteration - the same disc plays fine in my mp3-enabled radio in my Jeep.
I've looked at encoding software, bit rates, stereo vs, joint stereo - you name it - I've looked into it.
Odd thing tonight was that different songs from the same cd, that was ripped at the same time - some work, some don't.
The service guy at my dealership looked at me like I was crazy today. He told me to contact the motor company - who's probably going to send me to Harmon Kardon - who's probably going to send me back to the dealership.
I refuse to give up.
Old May 28, 2008 | 03:21 AM
  #34
driesb's Avatar
driesb
ORIGINAL: jayman720
It seems the disc is ok since you can play it in the Jeep. Therefore I'd assume the problem lies in the CD-Player on the bike. Either it has a problem with reading the disc or it is a problem with the player.
You could check thedisc capacity? Discs come in 74,80 or 90 minute (650, 700 or 800Mb) versions and I know several devices have problems with 90 minute discs. Personally I do not use the 90minute CD's since they give too many problems.
There also is a huge quality difference between the different brands of discs, are the ones you use cheap no-names or a decent brand?
With audio CD's the disc can become low quality when burned at high speeds. MP3 discs are data discs so they should not suffer from high burn speeds but it might be worth trying.
As a last check I would try to find somebody with the same bike from the same year and try the disc on that machine, see if it shows the same problem.
If it does show the same problem it seems to be that the player cannot handle this type of discs. (different brand, capacity, burn speed).
If it does not show this problem I would say the player is bad and needs to be replaced.
Good luck!
Dries
Old May 28, 2008 | 05:56 AM
  #35
mindfd's Avatar
mindfd
6th Gear
Download from Limewire for free. Transfer songs to a new playlist you have set up in your IPOD playlist library. Burn that playlist onto a MP3 CD. I'm getting around 160 songs per CD with no problems.
Old May 28, 2008 | 06:16 AM
  #36
CiSmAXz's Avatar
CiSmAXz
ORIGINAL: jayman720
Goes back to what i said. I don't think there is a problem with your mp3's I think it is just an issue with the radio. Like I said I have had a similar problem. I wish the website for downloading the updates told you what version it was and if it has been updated. I don't see it unless I am missing it. I just usually download the file every now and then and check the file version.
Old May 28, 2008 | 08:13 AM
  #37
Bertk's Avatar
Bertk
ORIGINAL: Windup08
My 08 Ultra doesn't have a problem with more than 150 songs....I've got a couple CDs that have around 180, and they all play.
Well it appears the manual is wrong.
Old May 28, 2008 | 08:26 AM
  #38
Phurion's Avatar
Phurion
ORIGINAL: Leftcoaster
I've never been able to burn any Itunes downloads to a disc. Always get a window telling me certain songs (from Itunes)will not burn. If you know a way around this please pm me with instructions.
Anyone who wants to get around DRM might want to check out this lil proggy.
http://tunebite.com/en/remove_drm/index.html
It's very nice.
I've purchased tracks from Napster, but even purchased tracks can only be burned to CD a maximum of 5 (yes FIVE) times.
SCREW THAT! I bought the damn song. It's mine to do with what I want now. So I use TuneBite to completely strip all DRM so now I can burn it to as many CD's as I want and can put it on as many portable devices as I want without anymore DRM headaches.
Of course it (TuneBite) can be used for "other" purposes as well. /wink
Old May 28, 2008 | 08:27 AM
  #39
diebolt's Avatar
diebolt
Bertk
It is based on the length of the songs. I have a CD that has 212 songs at 694MB total. 12 hours and 36 minutes in length.
Old May 28, 2008 | 09:11 AM
  #40
Bertk's Avatar
Bertk
ORIGINAL: diebolt
Bertk
Thanks Jim, that's good to know.
