mp3 CD issue - still...
Old Aug 19, 2011 | 04:08 PM
  #51
VineRider's Avatar
VineRider
I had the same issue. The problem is IDV3 tags in the MP3 file. You can remove these easily with a free program called WinAmp (http://www.winamp.com). Simply open the program, select the file you want to edit, hit alt 3 (or right mouse click the file and select view file info). Uncheck the "include IDv3 tag in file" checkbox, then hit the OK button. You need to do this for all the MP3 files you want to burn (or at least the problem files that won't play).
This solved the problem for me. However, I've found that the HK CD player is pretty finicky and some files still seem to have some issues, but this solve the majority of my problem of files being skipped over.
Hope this helps...
Old Aug 19, 2011 | 04:11 PM
  #52
VineRider's Avatar
VineRider
Hit send to quick...My capture is incorrect. You need to select the ID3V2 tag. See updated shot. Sorry for the mis type.
Old Aug 20, 2011 | 01:30 AM
  #53
Golden State's Avatar
Golden State
ok, after trying numerous things... i stand corrected. it IS the album art. I looked through all the songs that played correctly on my deck, and none of them had album art embedded in the file. all the ones that did were skipped over by the deck. so, in itunes, i went into the "get more info" on each mp3, and deleted all the album artwork. i burn the new playlist as an mp3 cd... and boom. it worked. every single song worked. it was kind of a pain in the *** figuring it out... but that was the ultimate issue... the album artwork.
So... in closing, it will play pretty much ANY mp3 file. ID3 tags don't seem to an issue, that harmon kardon deck just doesnt like embedded artwork. for some odd reason.
Old Aug 20, 2011 | 07:00 AM
  #54
VineRider's Avatar
VineRider
Good to know...curious that the only way I could get mine to work was to remove the ID3v2 tags. I'm going to try just removing the art next time. Thanks for the follow up.
Old Oct 11, 2011 | 02:52 PM
  #55
rowle's Avatar
rowle
Been having this track missing trouble on my new 2012 ultra and just found this thread.
took off the artwork as suggested from the MP3 file and its all working fine !
you lot on this forum are amazing - thank you very much.
Rowle- UK.
Old Mar 30, 2013 | 07:58 PM
  #56
Lanjo's Avatar
Lanjo
3rd Gear
This same issue has been driving me crazy on my 06 Classic. Going to try removing the art work as suggested and hopefully it fixes the problem. Still bull if they have not released an updated firmware for the deck that address the embedded album art You spend time cleaning up all your mp3'c (Adding album work, etc.) and you need to strip it off so it will play on an HK deck???
Fingers Crossed!
Oldman Harley
Feb 23, 2009 11:16 AM
jayman720
General Topics/Tech Tips
Jan 15, 2009 05:05 AM
shekmark
Aug 18, 2008 10:11 AM
jrudicel
Oct 19, 2006 05:36 PM
alazlo
Jul 27, 2006 01:15 AM
