I cannot post a reply for some reason
I have the 2" baffles now, I have popping on decel and between gear changes
Friday after work it popped so loud when it started it just about blew my eardrums out!
Man this site is relly screwed up, took 4 atempts to post this!!!?????
Popin isn't a good thing.. \\; If you don't have a Fuel Management System already then you should that HIGH on your need to get things... \\; Do you know if you have a Air Filter KIT???
I have the same issues on my 06 Ultra I run V&H ovals, V&H fuel pac, increased air flow filter. I have tried to fix it by reprograming, no help. Make sure you don't have any exhaust leaks this will cause it big time. I am bringing mine up to a 95 right after Laconia Bike week so I haven't tried any furter investigation.
I recently changed slip-ons from V&H to a quieter muffler and although mine is not injected, it required a serious jetting change. This was on a 95" hi-comp (10.5:1) engine. It also required an ignition change. Depending on the difference in back pressure on the different mufflers, you may likely find yourself needing an ECM re-programming.
I have vance and hine true duals with rush slip ons, \\; if I needed to quiet it down will it be ok to just slip the stock mufflers on?
You can put the stock mufflers back on the bike but it isn't a good idea. Take a look in the left side muffler and you will see why. Each mufflers flows differently so you will have some serious tuning problems if you try it.
