Stators
Old Jun 26, 2008 | 10:32 AM
Big Peter's Avatar
Big Peter
Default RE: Stators
ORIGINAL: drrandall1
ORIGINAL: Zimbob
Have you checked the regulator? I'd have the whole electrical system checked. As stated above, the stator and rotor needs to be a matched set.
&nbsp\\;\\\\\\;
Can you explain this more. I get a clank sound in my front end when I apply the front brakes sometimes. My small Indy said something about a stator. Not sure exactly what a stator is. What does it have to do with the rotor? Thanks
&nbsp\\;
The clank sound in the front end may be caused
by a "loose" brakepad.
Check the anti rattle spring in your calipers.
I've had the same on my bike
BTW this has nothing to do with your stator.
&nbsp\\;
Peter
&nbsp\\;
&nbsp\\;
Old Jun 26, 2008 | 11:03 AM
Dr.Hess's Avatar
Dr.Hess
Default RE: Stators
If you're blowing OEM stators installed properly, you have a problem somewhere else.&nbsp\\; Likely an intermittant short.&nbsp\\; I'm surprised you're not blowing regulators first/also, and regulators should be replaced when you do a stator.&nbsp\\; On my 79 POS, I went through several stators and regulators, then one day when I was changing the fork oil and had the covers off, I found that half the flag connector on one of the switches was blown off from it shorting to the fork tube intermittantly.&nbsp\\; Fixed that and never had another problem with stators/regulators.
&nbsp\\;
Bullys FLSTN
EVO
23
Oct 5, 2024 11:55 AM
FXD2003
Electrical/Lighting/Alarm
Feb 20, 2017 04:58 PM
ultra97
EVO
Aug 21, 2010 12:00 AM
BB4xl
EVO
14
May 25, 2010 04:39 PM
twistedcherokee
Aug 13, 2009 07:53 AM
