Born on Date
Old Jul 2, 2008 | 09:40 PM
Richpend's Avatar
Richpend
Default Born on Date
Where can you find the Born on Date on the flhtcu?&nbsp\\; I was actually looking for the month my bike was made.&nbsp\\; I have been reading a lot about the&nbsp\\;fuel canister problems on the 08!?
Old Jul 2, 2008 | 09:46 PM
MACK's Avatar
MACK
Default RE: Born on Date
That is tough once the packing stickers have bn removed but a good indicator is the VIN or the stickers found inside the saddlebags.
Old Jul 2, 2008 | 09:55 PM
Medicfrost's Avatar
Medicfrost
I removed the tank from my 2002&nbsp\\;FLHP-I, and found label with&nbsp\\;the date 10/17/01 on the frame underneath it.&nbsp\\; I don't know the significance of the label, or what years it is present on.&nbsp\\;
Old Jul 2, 2008 | 10:54 PM
acid_chipmunk's Avatar
acid_chipmunk
There should be something with a month and year somewhere near the front of the bike. I am still looking for it on the Ultra, but on my Sporty, it is on the right down tube.
&nbsp\\;
I am looking for the build date also, as I have an '08 and am worried about the fuel pump problem.
Old Jul 2, 2008 | 11:12 PM
onlythebest's Avatar
onlythebest
My 07 SG is on the inside of the left side cover. Month and year with initials in ink.
Old Jul 3, 2008 | 12:34 AM
DZLDR's Avatar
DZLDR
On my 08 Roadking Classic, turn handle bars full right, pull down on wire harness at top of frame and there is a data plate with serial number and "born on date" under the harness.
&nbsp\\;
ORIGINAL: Richpend
Where can you find the Born on Date on the flhtcu?&nbsp\\;\\\\\\; I was actually looking for the month my bike was made.&nbsp\\;\\\\\\; I have been reading a lot about the&nbsp\\;\\\\\\;fuel canister problems on the 08!?
Old Jul 3, 2008 | 12:49 AM
kg4epz's Avatar
kg4epz
Yep,
This is exactly where the month and year is located.
You should have gotten a born on certificate with any new bike purchase, I know I did.
Mine was borne on 4-23-07 and I purchased on 5-5-07, 12 days later. She was fresh! In the crate and never been farted on.
RC
Old Jul 3, 2008 | 12:51 AM
dawg's Avatar
dawg
If you lift up the can and look on the bottom you can usually find the born on date.&nbsp\\; Most of the times they have it listed on the outside of the 12 pack carton also.
Old Jul 3, 2008 | 09:18 AM
iann8ik's Avatar
iann8ik
my salesbabe gave me the configuration sheet that travels down the assembly line with the bike. birthdate is 8-20-2007 (a Monday).
Old Jul 3, 2008 | 09:23 AM
garyhendley's Avatar
garyhendley
i found all the info on the top of the neck behind some wires a little nameplate and stickers
