 \\; \\; \\; I have a 2008 Street Glide has 6200 miles, today the netural light stays on even when in gear. Seems a little dimmer in gear and sometimes flickers a little. Anyone have any suggestions
My Ultra had a similar issue. Usually happened only when it was hot. Someone else on the board had mentioned that Service Bulletin
M-1205 corrects the problem with new switch, P/N 33926-06B. The dealer acted like they'd never heard of the problem, and it took them two days to fix, but I haven't had the problem since.
Sounds like the neutral switch to me. Mine has been replaced twice and I still get the problem once in awhile when I run at highway speeds for long periods.
If Neutral light is on it IS in neutral ... Don't you dare ride in that condition - unless it's down-hill and with the wind in the back \\;
Take it to the stealer ..
I had the same problem with my 2007 Ultra classic. I took it to the dealer and, after waiting 3 hours, they said all they had to do was to clean the terminals on the neutral switch. Before I could get it home, the same thing again. I took it back and, after another 3 hour wait, they replaced the neutual switch. No problems after that. The problem I would have was not only would it not go out, but sometimes it would not come on! Difficult, but not impossible, to find neutral when the light does not work! I complained to H-D headquarters about the poor service, but..................
 \\; \\; \\; \\; \\; \\;&n bsp\\; \\; \\; \\; Halfbreed
It is your neutral switch, and there is \\;NO adjustment. \\; This usually happens when it gets hot and when it cools down you will see it back to Normal. \\; The part number now is 33926-06C, which means they are on their fourth revision of the switch.
I decided to spend the $18 on the switch and replace it myself as opposed to waiting at a dealer to do it under warranty. \\; It is a five minute job as the neutral switch is easy to get to with \\;a socket.
 \\; No matter what they tell you, terminals too loose, etc....There is no adjustment. \\; \\; The switch needs to be replaced. \\; Mine went bad at 7500 miles on an '07 ultra.
Mine went bad on the way home the day I picked up my 07 Ultra. The neutral light would come on whenever it got hot. Three service visits and three tries finally they replaced the switch. It's  \\;been fine for 18 months now. Insist they replace the switch and stop screwing around.
