Fuel Filter Canister Help !!
Old Jul 24, 2008 | 05:55 PM
swicegk's Avatar
swicegk
Default Fuel Filter Canister Help !!
I've got the top plate loosened but can't figure out how to release the electrical&nbsp\\;connector on the bottom of the top&nbsp\\; plate. I have the service manual but still can't get it to release. For those that have done the change, can you help out?
Old Jul 24, 2008 | 07:15 PM
hdblk2003's Avatar
hdblk2003
Default RE: Fuel Filter Canister Help !!
hry check out the thread about fuel filter shell failure.Someone has done this themself and has pic .there are about 2 pages about this problem....Jay
Old Jul 24, 2008 | 09:13 PM
swicegk's Avatar
swicegk
Ok, just finished changing out the canister. Didn't have to undo the electrical connector under the top plate after all. Went back and looked at Dawgs original post and saw that he didn't either. Just took a little force to get the canister free from the tank enough to loosen the connectors on the fuel lines. Mine had very slight stress fractures on 3 of the 4 tabs. My bike was built in July 07. For those considering changing before failure, do it yourself, don't pay the dealer. Fairly easy just need to&nbsp\\;have patience.
Old Jul 24, 2008 | 10:25 PM
hdblk2003's Avatar
hdblk2003
hey how many miles do you have?
Old Jul 24, 2008 | 11:22 PM
Jimbo59's Avatar
Jimbo59
swicegk,
&nbsp\\;
Good deal.&nbsp\\; Glad to see you gotter&nbsp\\;done.&nbsp\\; Dude, I changed mine out yesterday, and I believe it was just in the nick&nbsp\\;of time.&nbsp\\; One of the tabs was pretty much cracked all the way through, on one side,&nbsp\\;and the rest had stress cracks in each of the corners.&nbsp\\; My build date was 08/07
Old Jul 25, 2008 | 06:54 AM
RCruising's Avatar
RCruising
Mine was stressed on three tabs and all but broke on the other. After reading about this problem here I figured I had better check mine.
When I started the bike and looked inside the fuel tank there was fuel spraying across the tank, so I took it apart and found the crack/stress marks. I reassembled the bike and told the dealer that I had a problem ( didn't tell them that I had taken it apart ) and they agreed to fix it under warrenty. Should be done tomorrow.
Old Jul 25, 2008 | 07:12 AM
RCruising's Avatar
RCruising
08 Ultra, 5200 miles, build date 08/07
Old Jul 25, 2008 | 07:18 AM
2005UltraNC's Avatar
2005UltraNC
More MoCo - cheapest bidder crap.&nbsp\\;Probably made in China.
Old Jul 25, 2008 | 08:50 AM
swicegk's Avatar
swicegk
Quick Question, what do you think causes the failures? Is it the 58 lbs of pressure when the fuel pump is operating and putting force on the u clip anf tabs that holds the canister in place?
Old Jul 25, 2008 | 09:56 AM
Windup08's Avatar
Windup08
Did you follow the service manual to relieve the pressure in the fuel lines? Something about removing the fuel pump fuse and running the bike till it dies, then remove maxi fuse?
