Interesting Discussion about AMSOil
Old Aug 10, 2008 | 08:55 AM
  #61
Wally's Avatar
Wally
Originally Posted by jcbpa
Ahhhhhhhhhhhhh!!!!!! Now what do I do???? Man this one is too slippery for me, I just put in Amsoil... seems good to me, I guess I take a quart with me on any long trip, just in case... how often do you change the synthetic.
On a long trip, you'll probably service the bike when you get home and your nearly there when you need to add. No need to cart around a bottle of amsoil if something else will get you home.
I needed to add oil last year 150 miles from home, at the end of a 4,000 mile trip. I had the amsoil with me, but wouldn't have carted the bottle around all that way had I known.
In addition, as I said above, I dumped it out the next day when I changed the oil.
Old Aug 10, 2008 | 10:39 AM
  #62
Mac57's Avatar
Mac57
The parts manager at your dealership is just plain wrong. Either he is deliberately BS'ing you, or he just does not know what he is talking about. It amazes me how such an idividual like him can hold the position of manager. Kind of makes you wonder about the ability of the dealership as a whole. Amsoil is one of the best lubricants on the market. Amsoil has earned it's reputation in every field of motor competiton it has become involved in. If professional drivers and engine builders speak highly of the product, I would give their word more weight than one "parts manager" in one dealership. The manager in question is probably just trying to boost sales of H-D items including lubricants. Can't blame him for that, but buyer beware.
BTW. I use synthetic lubricants including Amsoil.
Old Aug 10, 2008 | 01:10 PM
  #63
The Nev's Avatar
The Nev
Does anyone know anyone that has had a failure based on a brand? If it was caused by a brand then there would be multible failures then everone would know about it.
Old Aug 10, 2008 | 01:18 PM
  #64
captjon37's Avatar
captjon37
If you want some truth about the oil you use then send a sample in to a lab. I do and it tells me what i have and how well it's working. I use Amsoil and they do the testing but i choose to use another lab for an outside source. I am waiting for the results on my truck. The oil has been in it for 10 months and 7k. Cost a few bucks but the information is worth much more than opinions.
Old Aug 10, 2008 | 01:30 PM
  #65
newrench's Avatar
newrench
I tore a 2003 ultra down to stroke it to a 103", it had over 80,000 miles and only used amsoil.
found everything including oil pump in great shape.
was it the oil? we can only assume.
Old Aug 10, 2008 | 01:51 PM
  #66
Chicago Spike's Avatar
Chicago Spike
AMSOIL IS tested on motorcycles and made specifically for motorcycles. He's just trying to prep you for repair warranty denials. Don't let him deny anything.
Magnuson-Moss his *** if he does
Old Aug 10, 2008 | 01:58 PM
  #67
iclick's Avatar
iclick
First, there's no way Amsoil itself caused engine damage. It is an excellent synthetic oil among many other excellent products sold today--including Mobil 1, Royal Purple, Redline, etc.
Second, there is no advantage to using motorcycle-specific oils over "car oil." I ran a synthetic "car oil" (not Amsoil) in my '96 RK for 106k miles (now with over 115k) without any evidence of engine wear, and the heads were never removed from that bike. Oil consumption was unchanged and static compression was 160/160 at last test in 2006. The first test was in 1998 which was 155/160.
One year ago two friends with nearly identical bikes did a joint big-bore upgrade. One bike had 60k that ran Mobil 1 15w50 "car oil," and the second had 50k miles that ran Amsoil 20w50 (not sure which type). Neither of the pistons or cylinders on either bike showed any sign of wear, and the piston coating was still intact on both.
Don't believe your dealer when he states differently, as there is no evidence that I'm aware of that proves what he says. Ask him for it. Then check Motorcycle Consumer News and American Iron, among others, for articles and lab tests on oil. Both of these magazines concluded that the "car oil" was equal to the motorcycle-specific products and are available at a much lower prices.
Old Aug 10, 2008 | 02:38 PM
  #68
jjr's Avatar
jjr
Sounds like the typical stealer line of CRAP. Have been using Amsoil in all my bikes for years and zero problem!
Originally Posted by russl179
My bike, an 07 FLHTC, has 30K. I was having some problems with engine noise, backfiring, and starting. I was told that the lifters and may be the cams need to be replaced...all warranty work. The parts manager at my dealership told me that the possible cause of this is the fact I am using AMSOIL. He said AMS was tested using automobile variables, and was not tested using motorcycles. Therefore, it is not a "true" motorcycle oil. I said that it was stated on the package that it is for V-TWIN motorcycles. He said that is because they want to sell the product. The dealership sells AMS. So, if it is bad, why do they sell it? Have any of you heard this stuff about AMS. I have been using AMS since 15K and change the oil every 5K.
Old Aug 10, 2008 | 04:30 PM
  #69
skratch's Avatar
skratch
or it could have been a quality built part to begin with..... and would have looked just as good with any quality oil
Old Aug 10, 2008 | 07:07 PM
  #70
HarryDavidson's Avatar
HarryDavidson
Originally Posted by cruise_carter
Even though no starburst, I don't think Amsoil could put those on the bottle without meeting the API standards.
Sure they can. The Starburst costs money (which is why Amsoil doesn't have it) , but it also requires the oil co to A. submit oil for testing, and B. not change the formulation without re-submitting for testing. Amsoil MAY meet the requirements, but others DO meet the standards. Also, Amsoil MAY change formulations frequently, so the MCV that passes the test one time may not be the same MCV as you get when you buy a quart at the store.
Also, at least some car/cycle/outboard manufacturers SPECIFICALLY say it must bear the API Starburst...not sure if HD does or not. I take delivery of my 09 FLHT in September when I get back to the world, so I have no way to check this...maybe someoone can.
Harry
