Installing extended bars on my 08 RK
If you do a seach you will find tons of info on this.
I myself have spent plenty of nights looking for as much info on the subject and after reading post after post, I am going with the Wild 1 cubbys (WO572) so I can go with internal wiring as well, they are a 14 inch ape hanger, and have the slots in the bar cut out already to accept the throttle by wire. I would think anything over a mini ape (10" rise) you will need to extend the wires, as well as brake line.
Best advice I have recieved on this forum is to get a SERVICE MANUAL, not the owners manual, to have it as a back up.
Other than that, if you are not mechanically challenged, you should be able to get through it.
Last thing would be a heads up on the ABS if you have them. I do have them and they look to be the biggest challenge of the whole bar swap.
Just slow and steady, get to know the bike, have some pride in what you have accomplished, and save soom cahs as well.
Best of luck
On a side note I got all my stuff ordered from Johnny at www.HDBIKEPARTS.COM
Just give hime a call and he will take care of you, he is a stand up guy.
I think these are the same bars on the 08 Screamin Eagle RK. You can see them in the brochure. The bike even looks better in my opinion.
They also said the 08 RK is the only bike that you don't have to do any cable extensions for adding these. I paid 1.5 hrs labor. I think the bars were about $70.
If your dealer doesn't know about these, IM me and I'll give you the number to my dealer. They are very knowledgeable about them.
Hope this helps
Banks
