Changing Stock 08 Roadking Bars
Old Nov 14, 2008 | 04:35 PM
tonydeli's Avatar
tonydeli
Stage II
Default Changing Stock 08 Roadking Bars
I have a 08 FLHRC and hate the stock handlebars. I want to change to 12.5" chubby ape hangers. I've talked to 3 different dealers and got prices from $725 to $1800. The problem seems to be the fly by wire throttle, everyone seems to have a different view of the amount of work required. Has anyone changed out their bars? Has anyone used the 09 Heritage bars on their RK? I'm looking for help!
Old Nov 14, 2008 | 06:07 PM
dawg's Avatar
dawg
Use the 08 RK Police bars which are the heritage bars with TBW notches in them. Easy swap, no way should cost that much!
Old Nov 14, 2008 | 06:26 PM
agent58's Avatar
agent58
Use the Police bars.They are in the catalogue.good price and made for the bike(tbw etc.)
Hope this helps.
Old Nov 14, 2008 | 06:47 PM
Doug's Avatar
Doug
I put police bars on my 08 and I like them very much.
Old Nov 14, 2008 | 07:19 PM
Skidrow's Avatar
Skidrow
I have an '08 FLHRC and hated the stocks bars as well. I changed to the Wild 1's RK pull backs and had all the wires run internally. My indy charged me $350 for the install. The new bars are much more comfortable. Oh, and the throttle sensor is no problem. All of the Wild 1's bars have the notch cut out in the end. The sensor fits right in perfectly.
Old Nov 14, 2008 | 10:22 PM
wannabe's Avatar
wannabe
The Police bars are the same as the Heritage bars and they are a direct swap, my husband put mine on and it was not that difficult to do. No extensions on TBW or Brake Line needed.
Old Nov 14, 2008 | 11:22 PM
jcbpa's Avatar
jcbpa
I had the dealer change my bars to the SE bars and they are wonderful for me. Hop on a SE RoadKing at a dealer and see what I mean.
Old Nov 15, 2008 | 08:32 AM
Bertk's Avatar
Bertk
I recently installed a set of Khrome Werks 300515 +2 Wide Sweeper bars on my 2008 Street Glide and ran the wire internally. Here a write-up on the process, along with these pics.
From what I understand the heritage bars work with all existing wires and cables. If you are going to run the wire internally, then I would suggest purchasing the HD twist grip sensor replacement PN 32310-08 $80.46 to made running the wires easer.
If you have some mechanical ability and the service manual you can most likely do it yourself.
Old Nov 16, 2008 | 10:03 AM
tonydeli's Avatar
tonydeli
Stage II
Default Thanks for the help
I'll look into the police bars. I'll post back and let you know how I make out
Old Nov 16, 2008 | 10:31 AM
Deepsouth251's Avatar
Deepsouth251
The real problem with cost may be in what the new bars you have picked require as far as replacement of cables. The police bars everyone has spoken of, if the same as the heritage bars will not require any new cables, just the bars and the labor would be all that is involved. Just as an example, I just got a price to have a set of "HD tall boy" bars put on my 09 Ultra. The price of the bars themselves was only $149.00 but when the required parts list was put together(new cables and whatever other parts) the bars, cables, parts price was suddenly $743.00 before tax. And with labor this was going to push it to around $1000 for this bar swap. Check on the Heritage style police bars, it should greatly reduce your cost and you should really like them, I put a set on my 06 roadking and really liked the improved feel of the bike.
