Cam Install
Old Sep 9, 2008 | 07:59 AM
huffhuff's Avatar
huffhuff
heat the cam support plate in an oven to 200 degrees and freeze the other parts overnight then you won't need a press to disassemble and reassemble. inner cam bearings can be removed using blind bearing puller from AZ and new frozen ones installed using and old cam as the driver. the oil pump will self align if you install the screws loosely and rotate the engine a couple of turns then torque the screws.
Old Sep 9, 2008 | 10:07 AM
bazam9s's Avatar
bazam9s
Originally Posted by dawg
What do you plan on using for a fuel management?
Thundermax w/auto tune
Old Sep 9, 2008 | 10:11 AM
bazam9s's Avatar
bazam9s
Yes on the freezer and oven, Ardy on this thread send me this link and it explains that exact procedure..looks like it works great.
http://www.harleyhog.co.uk/
Old Sep 9, 2008 | 10:41 AM
C Clamp's Avatar
C Clamp
A winter project for me too. Too many have mentioned they need to be upgraded. I am still trying to figure out what cams to go with. I will be watching and checking back.
Old Sep 9, 2008 | 10:49 AM
scootertramp's Avatar
scootertramp
Originally Posted by bazam9s
The bike only has 5500 miles on it...is it safe to say that the runout is tight, of should I still check t be sure?
yep. check that run out. Mine was .005 at 1000 miles so I went with the Andrews 37H cams instead of gear drive. Nice mid range cams and I don't have any problems hitting my rev limiter at 6300....
Old Sep 9, 2008 | 11:10 AM
Harleypingman's Avatar
Harleypingman
You can compare cam specs using the BigBoyz cam comparator:
http://www.bigboyzcycles.com/tccams.htm
This pic from the SE parts catalog shows what the open/close numbers mean:
http://
I have HQ-0034 cams in my 88; excellent bolt-in cam with many happy HDF'ers using it and its '07 and newer version, HQ 500.
Really woke-up my 88.
Good luck with your project.
Old Sep 9, 2008 | 12:46 PM
bazam9s's Avatar
bazam9s
Carl, so if I'm reading your chart right the exhaust valve duration is 260 and the intake is 252. So please school me. In comparing different cams what role does the duration play in HP/TQ gain? Or does it? Also what is Overlap...is more or less better?
BobFLHT2002
Engine Mechanical Topics
Jun 7, 2018 08:27 AM
GoofySB
Jan 12, 2016 07:27 PM
steelpony16
Sep 27, 2013 03:58 PM
SURFOR Chop
Exhaust System Topics
11
Jul 31, 2010 08:59 PM
bubbas1
May 20, 2009 08:34 PM
