ignition switch install problem
Old Sep 12, 2008 | 01:29 PM
Born2cure's Avatar
Born2cure
Default ignition switch install problem
Hope someone can help. Just installed chrome accents around ignition switch and switches. looks good. got the ignition switch back together turns all direction and locks the front wheel with no problem. except the switch will not lock unable to turn key and do not want to force. Any recommendatons
Old Sep 12, 2008 | 01:46 PM
timvan's Avatar
timvan
turn your wheel all the way to lfet lock, the same place you should have removed the switch from
get a flashlight and a small flat blade screwdriver, use the light and look down the lock tube..you will see that the internals are not lined up...
line them up with the screwdriver and install your switch.
Good luck, it may take a few times.
Old Sep 12, 2008 | 01:50 PM
stro1965's Avatar
stro1965
And show us those chome goodies. I've been looking for something to go around the lower switches.
Old Sep 12, 2008 | 02:10 PM
Born2cure's Avatar
Born2cure
they appear to be lined up and the wheel locks okay to the left but the key will not turn to lock.
could missalignment cause this
Old Sep 12, 2008 | 02:46 PM
rocknrod's Avatar
rocknrod
It takes alot of playing with it. Take a nap come back and try latter.
Old Sep 12, 2008 | 03:11 PM
HarleyWood's Avatar
HarleyWood
Thats what I do....oh wait...we're talking about ignition switches...never mind..
GRUNT77
Oct 30, 2018 07:46 PM
louisluongo
Feb 12, 2015 07:42 AM
bearammus
Mar 6, 2014 08:08 PM
gwphelpss10
Jun 14, 2012 11:36 AM
scootryder
Apr 22, 2010 04:16 PM
