Engine Compression Problem-
Old Sep 16, 2008 | 07:53 PM
russl179's Avatar
russl179
Default Updated
HD told my mechanic to check the cams and make sure that they are lined-up and are functioning properly. If this does solve the compression and the starting issue, it is caused by the cylinder, pistons, and rings. So, it is an easy cam fix or a big time fix.
Old Sep 17, 2008 | 08:41 AM
claydbal's Avatar
claydbal
since it is stock, here are the options.
1. cams are in time, but advanced a tooth.
2. 255 cams are installed
3. bad gauge.
i guess #3. but we do know one thing, it is not from cylinder/piston/rings. and your tech is an idiot.
Old Sep 17, 2008 | 03:13 PM
russl179's Avatar
russl179
3. bad gauge.
I totally trust this mechanic.......
Old Dec 18, 2008 | 09:31 PM
vettedog72's Avatar
vettedog72
So what is the answer?
Old Dec 18, 2008 | 10:09 PM
brnew's Avatar
brnew
Originally Posted by maineultraclassic
At 210 PSI, a match a good cam to that and you'll have a great running machine on your hands.
Hard hot-restarts are a real pain in the ***, compression releases will fix that.
Steve
How much is involved when you do compression release valves if he had to do this? Don't the heads have to be removed?
Old Dec 18, 2008 | 10:15 PM
StreetGlider56's Avatar
StreetGlider56
Carbon on the pistons/combustion chamber.. makes the chamber smaller.. run some cleaner thru the fuel...
Old Dec 18, 2008 | 10:21 PM
cmcsns's Avatar
cmcsns
From: Beverly Hills, Fl. Swimmin pools. Movie stars
Soooo...... WTF was the problem???
ohioflhs
Engine Mechanical Topics
29
May 27, 2015 02:06 PM
just plain john
Feb 16, 2015 02:50 PM
Benito
Exhaust System Topics
13
Aug 5, 2011 01:58 PM
masterblaster
Oct 4, 2010 03:22 PM
Papamte
Aug 18, 2008 08:53 AM
