Clutch Cable lubrication 08 EGS
Old Sep 25, 2008 | 08:41 AM
jdman's Avatar
jdman
Default Clutch Cable lubrication 08 EGS
What is the secret to lubricating the clutch cable that the dealer won't tell.I want to do my own.Thanks
Old Sep 25, 2008 | 09:03 AM
harley-jones's Avatar
harley-jones
Did you try a Service Manual? Might help...
Old Sep 25, 2008 | 09:06 AM
rocknrod's Avatar
rocknrod
Yep it's all there in the service manual
Best $50.00 you will ever spend.
Old Sep 25, 2008 | 09:25 AM
miacycles's Avatar
miacycles
Back the cable off all the way, remove the cable from the clutch handle, pull the outer housing to seperate the cable at the adjuster, put some cable lube(can be bought at any motorcycle shop, even bicycle shops carry it) down the bottom part of the cable. Then put some lube down the upper part of the cable. Re-install the cable to the handle(you can also check the adjustment of the clutch before you take the slack out of the cable. Take the slack out of the cable, leave about 1/8th inch of slack in the cable. Pull the outer housing away from the clutch handle bracket, you should just be able to put a nickle in there if it is right. Don't forget to tighten down the lock nut on the adjuster. Hope this helps.
Old Sep 25, 2008 | 10:19 AM
Jinks's Avatar
Jinks
Don't over tighten the nut on the adjuster. Brake that, & you get to install a new cable...
Old Sep 25, 2008 | 11:05 AM
robzuc97's Avatar
robzuc97
Bet he rips the rubber boot!
Old Sep 25, 2008 | 08:02 PM
Skivvy9r's Avatar
Skivvy9r
Sounds like the voice of experience.
55ironhorse
Jun 10, 2014 09:12 AM
gliderman
Jun 5, 2014 10:39 AM
semiret
Aug 19, 2013 08:48 PM
danzio
Jun 5, 2011 01:59 PM
hotrod351
EVO
Jul 20, 2008 09:05 AM
