Front run/signal light delete????
Old Jul 9, 2010 | 09:59 AM
  #31
baggerbrian's Avatar
baggerbrian
Spike, Thanks man! I can't find the link in you post can you send it again? Maybe the admin deleted it.
Also.... I hear the same thing!
Ride Hard!
Old Jul 9, 2010 | 10:11 AM
  #32
Chicago Spike's Avatar
Chicago Spike
They are still there when I look at my post, anyway customdynamics DOT com if it deletes them for you?
http://www.customdynamics.com/plasma_rod_led_lights.htm
Find the "Plasma Rods" and here's what they look like when the bike is off. Just the small red line is all you see when you look real hard for them;
Old Jul 9, 2010 | 10:53 AM
  #33
07FLHT's Avatar
07FLHT
baggerbrian may not have enough posts/time on forums to see links
  #34
EasternSP's Avatar
EasternSP
Paul Yaffe makes a pretty cool turn signal kit which is a dingle LED mounted in the fairing windshield strip. You can clip the running light wire and only the blinker will be seen when you set it to blink. Other than that, the blinker is almost invisible. I applied it to my RG and got rid of the Shrek running lights. I will add a picture later today.
Note the turn signal eliminator piece that goes where the turn signal used to be. It holds the fairing on now.
In the second picture you can see the difference between the running light (on the left of the bike) and the blinker on (on the right side of the bike).
Old Jul 9, 2010 | 01:00 PM
  #35
tedcmiller (Cry Baby)'s Avatar
baggerbrian is only the second person I have ever heard refer to Harleys as circus wagons. A person on one of our European motorcycle tours selected BMWs over Harleys, but owned Harleys back in the states. I never did get around to asking him why he referred to Harleys that way. Maybe baggerbrian can explain it to me. I, personally, like Harleys.
Old Jul 12, 2010 | 04:01 PM
  #36
baggerbrian
@Spike - thanks for the info, I can see them now. Trick! I Like them.
@Eastern SP - I'll look that up for the front.
@CryBaby - I have an FLHX. Remember the old circus wagons with the lights and flags and calliope? IMHO, anything with too many add ons turns into a cicus wagon... like the "Fast and the Furious" import crowd with the neon, lights wings and crap hanging on a econo-box.
Old Jul 22, 2010 | 04:15 PM
  #37
baggerbrian
Default Russ Wernimont Desgin
Here is the solution, Russ Wernimont Designs LED cat-eye tail light and license plate mount. It has integrated Amber LED turn signals, pulses when the brakes are first applied and really bright!
Attached Thumbnails Front run/signal light delete????-photo.jpg
Old Jul 22, 2010 | 05:55 PM
  #38
dansflhti's Avatar
dansflhti
Remove the outer fairing and trace the signal light wires back from the lights to the connectors in front of the speakers.For the right light,the running light wire is blue or brn,doesn't specify for the FLHT bikes..On the left side it is violet or brn,doesn't specify.If you were riding a Road King it would be the blue wire that needed to be disconnected on both lights.But as stated in previous posts,you should be able to determine easily with a test light.
Another option is to determine which of the 2 contacts on the bottom of the bulb is the run filament and file it off with a small file,might work.
Dan
Old Jul 22, 2010 | 09:55 PM
  #39
r8rs4lf's Avatar
r8rs4lf
Here's an easier way, take a piece of black tape and cover one of the contacts on the bulb. There you go! That's what I did.
Old Jul 22, 2010 | 10:24 PM
  #40
geezer glide 56's Avatar
geezer glide 56
Originally Posted by DrPlastic
Those lights are REQUIRED by every state in the US by federal DOT law. Removing them will lead to nothing but added harassment by LEO and the danger of you getting hit by a cager.
Then you will come on this forum and lament.
You may or may not have a state inspection requirement but there are laws requiring them to be there if you operate on any public road.
I wonder how the Buell blast got away without having running lights on the front signals.
FFLETCHER
Sep 11, 2012 07:07 PM
schulze
Apr 5, 2012 03:57 PM
Gooberguy
Jul 20, 2011 09:48 AM
cavalier2000
Jun 6, 2011 05:52 PM
Filmy
Mar 31, 2009 10:49 AM
