Some thoughts on fairing brackets
Old Dec 16, 2010 | 07:45 AM
Scorpion07's Avatar
Scorpion07
Originally Posted by tincup64
are the new beefed up ones installed in the newer bikes? like my 2010 limited?
thx - tin
2010 has the new updated brackets.
Old Dec 17, 2010 | 07:17 PM
tincup64's Avatar
tincup64
thanks
Old Dec 17, 2010 | 10:27 PM
xdanman's Avatar
xdanman
Default re
Subscribed
Old Jan 29, 2011 | 10:43 AM
Arizaino's Avatar
Arizaino
Originally Posted by iclick
I'm not sure the verticals will break now, as the weak points were indeed very weak, but time will tell. It did occur to me that they're purposefully engineered that way. One person on another thread thought HD might've done that to allow the brackets to break before something else more important did, like the fairing plastic. Or, perhaps as a means of keeping warranty costs down. As you suggested, if a plastic part on the fairing breaks, like the point at which the brackets mount, it would require a new inner fairing. Brackets are cheaper to replace than inner fairings.
I can't see that as a reason to engineer a weak point into the bracket, especially given the frequency of the breaks, but who knows. Since the problem is not new and HD doesn't seem to be upgrading the part, maybe there is a good reason for their reluctance to improve the design.
Some others have installed o-rings between the brackets and the mount to reduce vibration, but I wouldn't think that would make much of a difference, so I didn't try that. I did think about that or a rubber washer, however.
So, I'm one of the victims of the broken plastic attachment point on the inner fairing. I've done all the beefing up of the verts and horizontal brackets and like mentioned above, the next weakest point has to be the inner fairing. I've used the vertical plastic gusset pieces of the inner fairing for support of the vertical bracket by adding flat steel. I don't have a picture yet....I'm heading out this morning to check into another broken inner fairing mount on the opposite side. I'll take some pics this time. ....I heard on this forum that the broken inner fairing piece may be able to be bonded back in place with ABS cement. I may have to insert some sort of re-enforcement to the plastic........We'll see.
mikeyflhti
Nov 18, 2012 01:54 AM
iclick
Apr 10, 2012 01:07 PM
maineultraclassic
Jul 11, 2010 09:13 AM
Ultra61
Apr 29, 2010 12:20 AM
FastHarley
Jan 19, 2008 09:00 PM
