SE Pro 103 question
Old Nov 22, 2008 | 07:17 AM
fgunnr's Avatar
fgunnr
Default SE Pro 103 question
I ordered this kit from the local HD dealer and it is ready for the install.
Question
Would I get a better build if I used my cylinders and had them bored to match the pistons that are in the kit?
Thanks
Old Nov 24, 2008 | 12:48 PM
fgunnr's Avatar
fgunnr
I know the aftermarket has plenty of great builders but the local dealer is my best friend so he is doing the work.
Will boring out my cylinders give me a better build.
thanks
Old Nov 24, 2008 | 01:12 PM
103 dyna's Avatar
103 dyna
2nd Gear
I just got my o4 fxd back a week ago Its awsome! I blew my 88 and did the 103 swap at the dealership. I bored my cyilinders. I was told it would be better by my shops service manager, the mechanics in the shop and the performance consutant. I work for the dealership and I do trust them. the only thing about it is I had 30k on my bike with a silver motor so it still looks dingy but thats ok cause it looks like a sleeper. You can powdercoat but it will take longer and cost more. Good luck with the build your gonna love the upgrade!
Old Nov 25, 2008 | 02:09 PM
fgunnr's Avatar
fgunnr
thanks
Old Nov 25, 2008 | 02:39 PM
Scorpion07's Avatar
Scorpion07
A little off subject - but is the SE pro 103 kit as powerful as their dyno says?
I was thinking about going this route so I don't have to bore my cases.
What about fuel requirements?
Old Nov 25, 2008 | 03:14 PM
rochkes's Avatar
rochkes
A competent machinist at the factory or local should have no problem doing the bore. I say it's just a matter if you want you take off jugs or not. You could get a bad one from the factory, but you should know that before the warranty is up.
I think you'll like this build. I really like mine.
Dennis
coolmac's Avatar
coolmac
Forget the 103 kit, just install a set of cams that work for
your riding style.
Cheaper and better numbers.
Old Nov 25, 2008 | 04:11 PM
flhrsi's Avatar
flhrsi
Default 103 "kit"
I upgraded last spring to 103, 10:5-1, se 103+ heads, 257 cams, sert, se slip ons, It pushes 98-99hp, 105lbs tq, by the dealers dyno, it goes.........BUT when I do it again, this time I will port/polish the heads, they are wrinkle painted in the chamber and ports from hd, I would also choose different cams, these dont run out of breath, but the power band is a little to high. The bike does go, but I was expecting more for the money...
Old Nov 25, 2008 | 04:16 PM
rochkes's Avatar
rochkes
The 255 cams will put that powerband very low. Low end tq is their selling point.
Dennis
Old Nov 25, 2008 | 07:47 PM
dmgary's Avatar
dmgary
see my sig for my mods....YES you can have them bored and be just as good as new ones. Ask if the machine shop is using a torque plate. If not then i would not sue them. EVERY tuner/DYNO will get different numbers while you can boost about big numbers i have ATE big numbers up. I just moved to pensacola but while in jacksonville a friend rode a SG with 102hp/108tq and I rapped him and my lil ole bike is still in the 80's lol. But to answer your question yes you can bore them and be just as good.. Good luck and im sure youll love the new power ITS awsome.......
Darryl
nomad billy
Engine Mechanical Topics
Oct 13, 2015 06:05 PM
denman
Nov 25, 2010 04:13 PM
Born2cure
Sep 2, 2009 03:35 AM
dbianco
Oct 25, 2007 06:26 AM
ga4boats
Aug 22, 2007 08:41 PM
